Turn off phone charging
1038 7 2019-1-10
04in719
Flight distance : 151 ft
Might be a silly question but is there a way to turn off the osmo from charging the phone during use?
I ran out of battery on a hyperlapse cause it was charging my phone.
Thanks.
2019-1-10
DJI Paladin
Flight distance : 318 ft
Hi there, sorry for the inconvenience. According to AOA protocol of Android, Osmo Pocket must provide 5V 500mA power to the Android device when connected. This will result in reduced battery runtime, however, the Osmo Pocket allows you to charge it when it’s turned on. Adding an optional Wireless Module can also prevent the reverse charging from happening while not compromising advanced control and features.
2019-1-10
hkphoto.com
Battery charging limit in Google play may help but you need a rooted phone
2019-1-10
04in719
I appreciate the reply, using a galaxy S9. The short video doesn't really apply in this case, what good would it do?
Just want to know if there is a setting I'm missing.
2019-1-10
DJI-Osmo-User-1
04in719 Posted at 1-10 10:01
Unfortunately this is an android issue, a requirement of an accessory being plugged into your phone must provide power, this is why it charges and not the fault of the osmo.
2019-1-10
LouisP
Flight distance : 41952 ft
Unplug the phone while doing the hyperlapse.   You can set up the lapse with the phone then unplug it and press the button to start.  No need to keep the phone plugged in the whole time.
2019-1-10
04in719
LouisP Posted at 1-10 12:39
I had no idea you could do that. Thought the phone had to be attached. I'll test it out.
2019-1-10
04in719
Works great, thanks for the tip!
2019-1-11
