andy10
Flight distance : 4585692 ft
Slovenia
I was about to take a great scenery this morning when all the trees and bushes had white frozen branches and the land was dark with no snow.
I have P4P+ for a year and a half and never had any problems with it.
When I turned on the RC it starts beeping very fast and when I started the drone it continued doing that. The light remain red - as it would had no connection. Then a message appeared 'switch the aircraft off and calibrate the RC' I did that but after performed required stick movements and pushed 'done' the 'calibrate' option appeared and I pushed that too. Then a message came 'move sticks to the centre points and 'calibrate' and then to the sticks again etc. In short - I couldn't finish the calibration of the RC. Then I switched it off and on again (the RC and the craft) and it connected normally.
I was in a hurry as the sun began melting the frost from the trees and after a few minutes the scenery would gone. The drone flew normally I pushed it around at max distance 700m from the HP. I was looking for the best shots so I lost VLOS but was not worried as there were no elevations nor other objects around, just meadows and fields.
When I decided to bring it back I noticed a strange behaviour of the compass. The red triangle that marks the drone position and heading didn't move according to the stick movements. I didn't activate RTH as obviously there was some problem with the compass and the drone could fly away then.
I brought it back in the direction where the distance readings diminish the most. This was no problem as there was no obstacles other than some trees and I flied pretty above them.
Even when I had the bird just above my head, the compass marker showed different orientation than the drone had.
I took off in the middle of fields with no magnetic sources few 100m around. After I landed I turned the aircraft on again and then it showed the compass error. The drone flied normally all the time.
Sorry to be a bit long but I just want to know if the RC behaviour at the beginning have anything to do with compass issue later. Does the stick calibration has anything to do with the compass? |
