Tapfly Grayed Out
1592 2 2019-1-11
A4CH1L
Flight distance : 85873 ft
I recently purchased an Inspire 2 w/ X5S. When reviewing the Intelligent Flight Modes, Tapfly is grayed out, with the message "not compatible with this device". I have tried with both a Crystalsky and a Samsung Note8. Does Tapfly only work with IOS devices? Thanks in advance!
2019-1-11
DJI Tony
Hi, we're sorry for the troubles that it caused. May we know if you're using the 5.5-inch crystal sky? If yes, this feature is not yet available when using this type of crystal sky as of the moment. However, it should work on the mobile device that you're using. Would it be possible if you could provide the firmware and app version that you're using for further help? Thank you for the support.
2019-1-13
fanscfa151e0
Flight distance : 1319452 ft
Philippines
tapfly is greyed out. does tapfly work on iphone 7 plus using the i2? but when using a ipad, it is working fine.  can DJI confirm this?
2019-10-20
