Cetacean
Flight distance : 2455246 ft
Johnnyv Posted at 1-13 04:56
I think you are referring to Flight rule for licensed VFR and IFR pilots. They have a minimum altitude they must maintain above the ground , structures etc. I haven't flown a plane for many years so don't quote me, but I think the distance is 500 feet. The new drone regulations state a maximum altitude of 400 feet AGL. The idea is to keep separation between small aircraft and drones I would presume.
Aloha Johnny,
Actually, I am referring to the US Latitudinally below Canada and Outlier States like Hawai'i and Alaska. Of course we have different regulations but our regulations often have a shared resource, but not always.
In the US, under the FAA regulations, drone pilots (hobbyist and Pt. 107) have an altitude limit of 400 feet above a structure. Most often that structure is ground level. Manned aircraft have an altitude limit of 500 feet above a structure. This provides 100 feet of separation between manned and unmanned aircraft in the US. You noted a similar principle in Canada.
But, the key down here is altitude above a structure. I live in a jungle next to and below cliffs that max out at 2000 or so feet. I like to fly up to 1640 feet on the cliff and ridge faces - well within the 400 foot limitation. This 1640 feet is 500 meters and is the max altitude provided by the DJI computer limitation in DJI GO 4 and DJI GO.
It all works out well here for me. I hope the new Canadian regulations do as well as for you. Is there a structural equivalent in Canada for altitude issues?
Aloha and Drone On! |
