Motor parameters problem !
749 3 2019-1-13
Ventsislav
Bulgaria
Hi everyone, i have my Ronins S from 6 months ago and i'm verry happy with this. But before 5 days ago i press auto tune the motor parameters and something has gone wrong since then. Now the motors are drifting in the most of cases and the movement of the gimbal is not smooth. The camera blance is perfect, i try joystick calibration and all possible ways to calibrate the motors but nothing. I read carefully instructions about motor parameters but i still dont now what setting i need to change to get it results like before. The firmware is the last version. I want to know how to reset the Ronin in the factory condition.
2019-1-13
schoebox
I’m having the same issue after updating the firmware.
2019-1-13
Hi Ventsislav, sorry for the drifting issue with Ronin-S, may I verify if you have tried the System Calibration? The gimbal setup can be restored in Gimbal Settings, please have a try.
2019-1-13
schoebox Posted at 1-13 15:05
Hi schoebox, sorry to know you have the same issue, first, please make sure the gimbal has been balanced properly, then try the System Calibration and Joystick Calibration, if you ever changed any settings, please Restore the Gimbal Setup in the Gimbal Settings, thank you.
2019-1-13
