4K videos have 4gb limit - any fix??
3027 13 2019-1-13
verjen5
Hi Guys
I've seen this topic in some of the other threads but haven't seen any fixes
I recorded 17min 6sec of 4K/60 video with my Mavic air
I ended up with 4 files as follows:
4min 52sec file = 3.52gb
4min 51sec file = 3.50gb
4min 50sec file = 3.50gb
2min 33sec file = 1.85gb
I'm using a 64gb Samsung Ultra 100mbps Micro SD card and formatted the card through the GO 4 app using the exFat file system
File index mode in camera settings is set to continuous
I want to be able to record in 4K/60 for as long as my storage capacity on my SD card will allow and to just 1 large file not multiple 4gb files
I know I can reduce the res and fps and I will get longer files because it'll take longer to reach the 3.50gb limit but don't see why I should have to do that  - I want max res for max time - I spent a lot of money on this (like all of us) so I'd like to get my money's worth
Can anyone please let me know if there is a fix for this or a workaround - I'd be very grateful for any fix at all
Thank you in advance
2019-1-13
Landbo
Flight distance : 502792 ft
Denmark
Sorry but you never get a bigger file than 4 GB out of your Mavic SD card. You see that limitation on almost all cameras using a SD card.
However, you can merge your 4GB pieces you have to a large file with an external program like VLC, hand brake or video editor.
Regards, Leif.
2019-1-13
Landbo
Denmark
Ups, double post.
2019-1-13
Landbo
Denmark
Ups, double post.
2019-1-13
verjen5
Landbo Posted at 1-13 22:44
I have Final Cut Pro for video editing - and I’m just learning that as well - can you use that to merge files together?
2019-1-13
him7403
Flight distance : 374557 ft
have u tried ntfs?
2019-1-13
him7403
have u tried ntfs?
2019-1-13
verjen5
Nope - other people have said that format isn't compatible with Mavic - but I haven't confirmed that - have you??
2019-1-14
Chevy3717
Flight distance : 1438566 ft
I use Final cut pro, When you stitch the videos together the transition is SEAMLESS, I used to be irritated about  the 4GB file limit, But in reality there are many benefits to this. Huge files are not handled well with video editors for one.
2019-1-14
verjen5
him7403 Posted at 1-13 23:49
have u tried ntfs?
I formatted to ntfs - Mavic did not recognise the sd card
2019-1-14
verjen5
Chevy3717 Posted at 1-14 04:10
Ok thanks for the tip - I think youre right - it would be easier to edit with smaller files - I'll just do that
Cheers
2019-1-14
DJI Gamora
Hi there, thank you fo reaching out and we're sorry to hear about the trouble, About the file size, unfortunately, that is a normal phenomenon when it comes to the technology of the SD card you can just post-process it and merge all the videos.
2019-1-14
Rcplanedude
Flight distance : 117900 ft
smaller file size is better less chance of all your footage getting corrupted and it makes managing videos on editing programs less difficult
2019-1-14
JasonWilli
Have you try Data recovery Program for SD card? Please don't overwritten the SD card because overwritten data will not recover any program or technique.
2019-2-8
