Hyperlapse Shaking
2111 10 2019-1-13
bikoo
Flight distance : 1534987 ft
United Arab Emirates
Hello,
i just want to check if this is normal. please note it's not windy
https://drive.google.com/file/d/1hXmekEZDHbKlDUG_BJaIqN_FcZKrvqWa/view
https://drive.google.com/open?id=17AS5PcBcfCqpvTPa8GaJPkqVgvGp5LBT
https://drive.google.com/open?id=1g109eTuA3Tss9pN_snIu5HFy-3wOphAT
this link for normal vide which is 4k in 24fps  but i feel it's not smooth .. is this normal also ?
https://drive.google.com/open?id=1VUN8H8P4GlSD3wybNJjZVgfhlXZqhhx-
2019-1-13
saviour
Flight distance : 604203 ft
I can't see your videos but shaking in Hyperlapse is normal because you take pictures every X seconds and the drone is never perfectly balanced so you can see the shaking when you put those photos together.
If you do Hyperlapses automatically inside the app, the software will try to stabilize it, which will never be 100% done correctly.
If you do it manually (which I recommend, MUCH better quality and editing possibilities) you also have to stabilize the footage.
Either way, no matter what option you choose, you should always try to stabilize it using programs like Adobe Premiere Pro or AE.
2019-1-14
bikoo
Hi Saviour,
thanks for your reply, what is the error when you try to watch the video ? i share it public. is any one else facing the same error ?
i prefer to create it manually using the RAW files then the AP. but the original video from the drone was very strange!!
2019-1-14
saviour
I see the preview picture from youtube, click on play and then it says "invalid parameters".
2019-1-14
bikoo
saviour Posted at 1-14 04:42
can you try this link
https://drive.google.com/open?id ... t7IYByJXKQcBXU9cXA6
2019-1-14
saviour
Now it works.
As I said to the shaking - you have to use other programs to get rid of it. Sometimes it just won't get perfect but most of the times it works pretty well.
2019-1-14
bikoo
saviour Posted at 1-14 05:47
Now it works.
cool, but the video 181 is very strange for me !! i just want to tell you that's my drone was crashed and i just test it after i get it back from DJi.
2019-1-15
Steeve Labrie
Flight distance : 455919 ft
With this kind of effect, you need to retouch your post-production images with a stabilizer.
Have fun !!!
2019-1-15
bikoo
i tried with all of them using adobe priemiare  but still some of shaking specially  with video 181
2019-1-15
Ahmed Hussain
Flight distance : 1339761 ft
Kuwait
The reason because of the drone close to the bridge and you shouldn't be close that much to buildings  and such things while in hyperlapse. If you do so, this will be hard to stablize by any stablizer app.
2019-1-15
bikoo
Ahmed Hussain Posted at 1-15 08:24
thanks, i'll try again from  far distance
2019-1-17
