Fyrfyter
Flight distance : 412096 ft
I'm hoping someone can give me some insight to what is going on. My P4P started with the issue about a month ago. Up until then, no problems.
I launch my drone, and record the home point. The altitude is reading correct. I can go up about 50', and come straight down..... and the altitude will read about 15' on the tablet, when in actuality it is only about a foot off the ground. I can launch and do a circle approximately 200 yards out, and when I come back to land, it will read up to 40' off AGL. (WHen it is about to touch down.).
I've recalibrated everything, IMU, compass, vision sensors. Different batteries, Everything. Can I have a bad barometer within the drone? Can they be replaced?
Help me. All of my saved missions are useless now with a 40 ft higher reading that what is actual.
It'll reset to 0 once it touches the ground. Is there a barometer that can be changed out to see if that is the problem.
Where should I go?
Les Pratt
972-743-4584
Firefigter/Paramedic
Irving, TX Station 12 C
