Spark in the Park
Flight distance : 725961 ft
Ive owned both, in all honesty spark is better all round, mavic air has so many issues and bugs, it over heats sending out main controller data errors, the error is with the barometric data due to the heat of the drone interfering with atmospheric readings thus giving the flight computer corrupted data. Then there is the dji assistant not being able install drivers for the controller, there is issues with stability with the ma especially when there is wind, there are issues with decent speed so emergency landings can be very perilous. Ive had my fair share of dramas with every single dji drone ive owned and have all been returned and replaced, the spark is the only one that was consistent every flight. Occasionally i would get a error where it said it was below ground level and be 20 meters up but that was just the gps swapping to vps mode for safety so i found out. Range was a bit hit and miss on the spark, ma is much better in that regard but still not perfect. More bugs all round |
