Infinite Roll- Shooting to Sky & Pointing to ground
1384 1 2019-1-14
TracyCox
Hi there!
How do you program the Ronin -S gimbal to give an infinite roll when shooting directly overhead (pointing to the ground) or pointing directly skyward.
thank you!
2019-1-14
Hi TracyCox, Roll 360° is only available when using the Ronin-S in Flashlight Mode, if you would like to shoot to the sky or point to the ground, continuously rotating the Pan axis is recommended.
We have also released 3D Roll 360° in v1.6.0.50, enable 3D Roll 360 in the control settings of the Ronin app, the gimbal can switch between the three operation modes by pressing the trigger twice, then rotate the gimbal roll axis using the joystick. Please have a test to see if that is what you expect.
2019-1-14
