hallmark007
Flight distance : 9827923 ft
I’d suggest you go to an open area free of any magnetic interference and preform a calibration, after calibration check the compass values in your app, they should show as small green marks to show good compass, if you continue to get error you may need to return , but opening the Mavic may just void your warranty.
Compass distances.
Natural and Artificial Magnetic Anomalies Warning
Note
The following information has not been objectively tested to determine it’s impact on a Drones compass accuracy in flight.
1 Many things can distort the earth’s magnetic field in the area you are flying:
• Steel framed or reinforced concrete buildings, bridges and roadways, iron pipes and culverts, high power electric lines, heavy equipment, trucks and automobiles, steel tanks, electric motors and even computers.
• Flying between steel framed or reinforced high rise buildings will distort the magnetic field in addition to causing GPS multi-pathing.
2 Safe distances for compass calibration
• 6” (15 cm) minimum: Metal rim glasses, pen/pencil, metal watch band, pocket knife, metal zipper/buttons, belt buckle, batteries, binoculars, cell phone, keys, camera, camcorder, survey nails, metal tape measure.
• 18” (50 cm) minimum: Clipboard, data collector, computer, GPS antenna, 2-way radio, hand gun, hatchet, cell phone case with magnetic closure.
• 6 ft (2 m) minimum: Bicycle, fire hydrant, road signs, sewer cap or drain, steel pole, ATV, guy wire, magnets, chain-link fence, bar-wire fence, data collectors
that use a magnet to hold the stylus.
• 15 ft (5 m) minimum: Electrical box, small car/truck, powerline, building with concrete & steel.
• 30 ft (10 m) minimum: Large truck, metal building, heavy machinery.
