Satureyes
Flight distance : 524908 ft
cgbrian.com Posted at 1-21 19:02
I assure you that was not shot at 29.97. It would be rather choppy footage played back at half speed or anything slower than 24fps for that matter
I assure you that it was. It's my footage.
I shot it. I edited it.
So.. thank you for telling me what frame rate I used- but you're wrong.
I shot it at that frame rate because it's the only frame rate that I could import to my iPad and store as a backup. I was also playing with some on-site editing during my trip. The firmware update happened midway through my trip but the new frame rates were still incompatible with iOS so I decided to keep them the same as when I started.
I shot at 4k 29.97, imported into a 1920x1080 pro res 422 project at 24p. Some of the shots are cropped 4k images at native res -most are pushed into the HD frame size. Most shots are slowed to 80%. Some slower. The woman running was down to 50%. All the clips were set to 'optical flow' on the rate conform.
FYI here's a grab of the info for one of the clips. Is this enough proof for you?
