Aardvark
Flight distance : 384432 ft
If the Mavic Pro has switched to ATTI mode then it would likely be because there is no reliable GPS signal, between high buildings or canyons etc. And if there is no reliable GPS signal then it cannot RTH as it doesn't know where it is or where the home point is. If you're flying in open areas it's unlikely to be anything you would ever encounter.
An interesting point though, for on the P4 series you can manually switch to ATTI mode, where the aircraft does not lock its position based on the GPS signal even although it is available. In that case I would expect it to return home in most instances (other than loss of GPS) because the GPS signal would still be available to it. |
