aburkefl
Flight distance : 78612 ft
To choose between .mov and .mp4 format.
Look up in the extreme upper right hand corner of the pilot app. Just below that, click on the icon that looks like a camera. When the window opens up, look at the very bottom where it says "more."
Touch that and you'll see an option in there to alternate between .mov and .mp4.
For the gimbal setting you're looking for, try this:
In the upper left hand corner, touch the "flight mode" icon OR in the extreme upper right hand corner touch that little icon (mine looks like 4 dots - on some screens I think it looks like a little cog/gear).
Look along the left side of the window that opens up - the next to the last icon on the left side, near the bottom, is a gimbal. Touch that and look on the right hand side of the screen. If I remember correctly, touching what's in that little box will let you alternate between FPV and FOLLOW.
Look closely at that box on the left side where those icons are (the column where the gimbal icon is located) - if you use the pilot app very much, you should become VERY familiar with that column of icons - that's the quickest way I've found to get to major (non-camera) settings.
