Lysak2003
Flight distance : 500052 ft
Ukraine
Proteous Posted at 1-19 06:57
the case with modified antennas would give you extended range, you would also have a bigger screen
Simply switching into FCC mode gives you so extended range that you can reach with a Spark battery. You can see on Youtube many evidences of 2000-2500 metres flights. Actually I saw one for 4000 metres long in one direction to full drain of the battery. Why do you need any other extenders? |
