hallmark007
Flight distance : 9827923 ft
GlynH Posted at 1-24 09:53
Ordered a Mavic 2 Pro/Smart Controller/Fly More Kit/Care Refresh package as soon as I heard the announcement from CES and it arrived 4 working days later so guessing I must be one of the first in the UK to have one?
I really like it but only have a friends controller to compare it to.
To number 1, if you lost transmission you could fly the craft home, or you could press RTH and it will fly directly home, if you think it’s easier to fly without transmission than a direct RTH flight then maybe , matrix telemetry is something you will miss.
But I’m not so sure, it is both easier and safer to hit RTH when transmission is lost, I can’t think of any other reason to use matrix telemetry, unless you don’t have enough battery to RTH and maybe land, but even that once your in VLOS you would have that option even if transmission was lost .
I have once used it for fun when I wasn’t using it with my phone, which I can’t or don’t need to with SRC.
I’m not to sure what you mean in number 4, but it’s equipped with a very fast charger, you will really notice how quick this is just by trying any USB wall socket.
I think if you compare the build the components to a $1000 phone you will see the real value of this, I don’t see where corners were cut , compare it to Crystalsky and normal RC which would set you back $850 again you will see the real value. |
