Ray-CubeAce
Yan Mednis Posted at 10-15 03:15
Unfortunately, I am not able to contact the DJI Service Center. The nearest center is very far away and cannot be reached due to the coronavirus.
There literally 1 millimeter prevents the head from scrolling. If push it a little, then it moves. What if I peel off a little layer of material in the place shown in the figure so that the head can rotate freely? How do you think this will help?
Personally I don't think it will help as the vertical upright is bent, so the calibration will be out all the time. You may even then damage a motor assembly trying to shave off material. A person here did put up a video of how he 'repaired' his only to take it down again a short time after. It may have packed up shortly after or wasn't usable. Either way, it really needs a proper repair or if made worse could fail. |
