spandit
Flight distance : 65463 ft
Today I thought I'd try out TapFly mode as I have planted some blocks of trees with a ride inbetween them and thought flying up in between them at low altitude would look good. The ride is a good 15 feet wide and slopes uphill.
Started off trying to flying around my land by tapping in various places but a couple of times the drone started descending quite rapidly and I didn't know how low it was going to go.
I then stood at the bottom of the ride, facing uphill. First couple of attempts at clicking a point at the top led the drone to drift off to the left, to the point where I had to intervene before it hit the trees. I tried it in course lock, but it still kept drifting. Wasn't much wind, if any, especially below the tree line. I might try tomorrow at a lower speed. Terrain follow mode worked to an extent with the rising ground.
For some reason my Acer Iconia tablet had completely drained itself of power and after charging it enough for it to switch on, I thought it would charge from the remote. Seemed to be working until it suddenly shut down with the drone in the air. Fortunately, I was able to manually bring it in and land it without a problem - a good reason for always keeping it in sight, I suppose! I could have plugged my phone in with the same cable if desperate.
Got everything charged back up again whilst I was splitting logs outside. Was going to come in for dinner when I noticed the incredibly clear full moon which was still low enough to be behind some trees. It looked massive so I rushed inside and picked up the drone. The tablet was a bit unresponsive and although I got airborne in GPS mode, it suddenly went into ATTI mode and gave me some sort of error about "check app" - drone immediately started motoring off towards my neighbours but fortunately I still had some control and GPS mode came back in again. I have noticed it turns a bit in the hover - wonder if this is connected to the veering left issue? I calibrated the IMU yesterday and checked the compass and IMU performance in the app.
My neighbour has a vineyard with beautifully straight rows - if the weather is OK I'll go down there tomorrow and see if it's still drifting.
After all that, moon looked a bit crap anyway
