LarryLaxdal Posted at 1-23 07:17
I believe the question is: why does the M210 need the GPS if it's flying in RTK mode? The positional information is being provided by the ground station, and not the on-board GPS, no?
Thanks for your clarification, I will explain again. The position of the aircraft is being provided by the RTK air system, the ground station provides the calibration function which makes the drone to fly more precisely.
If you are referring to the external GPS module, it is not necessary to be mounted without mounting the upward gimbal. But if you mount the upward gimbal, it is recommended to mount the external GPS module.For the internal GPS, when enabling RTK, the drone will take off in P-GPS mode with RTK FIX.
