Cetacean
ManaRam Posted at 1-20 12:37
Question!!!
Not Drone related but I only use iMovie to edit my videos, all my videos are 1080 or 4k but when I saved this video it only allowed me to save it in 720 do you any of you guys know why???
I moved my first vide that was a 1080 to a 4k video and still it only allowed me to save it in 720.
Aloha Mana,
The 720 format is used for "Proxy" editing. The simple save function saves the project and saves it in the 720 format for further work - at least this is the way PC and PC editing works. To "Save" as a higher resolution and higher quality video, you have to "Export" the video and there you will get a broader set of options. Be sure to identify the original quality of the video as well as the resolution (FPS, bitrate, etc.).
If you are using a PC, Windows Explore has options above the files listed that allow you to have video qualities listed in columns next to the file. Right click on the Column Name Bar after listed names and more options will be available. I like height, frame rate, length added because it makes these files easier to work with.
Hope this helps!
Aloha and Drone On! |
