Buzzyone
Flight distance : 4647913 ft
The smart controller does fit in the case, as DJI Natalia said, two small foam blocks slide out and the smart controller slides in.
As far as the case itself goes, it's not bad at all, it lacks the finish of the MC Cases range, they have a nice red felt on the top surface of the foam, the DJI one just a textured finish to the polysterene block its made from. It's the same material that the Inspire inserts are made from and the Spark box.
Everything from a flymore combo fits in, with space for an additional battery so four in total and a handy deck under the drone to store the car charger and the power bank adapter, the latter fits flush and this makes it difficult to get out unless you have fingernails long enough to prise it out.
The case outer is good quality with seals and lockable case. The foam lid pad isn't glued in, but the lower part is, I think someone on here wanted to swap the internals to another vendors case, probably not possible.
Overall is good value for money and everything fits in well. as the foam block is made in one piece you don't get the glue lines seen on some of the cheaper cases. It's about on par with MC Cases offerings however if they start making a Smart Remote version of their Explorer case I would probably swap to that as their cases stack, the Mavic protector case does not.
