Thermal Analysis Software magic DUAL
12Next >
12003 40 2019-1-23
DRAGenDROP
Flight distance : 26170253 ft
Hello,
Where is your Thermal Analysis Software? DJI when there is no software we can do nothing whit the camera than only look for cows and horses!And where is the app like DroneSense from flir????
Vincent
2019-1-23
Lynfa
Switzerland
I'm interested too. But as long as they do not allow you to export RAW or JPEG images with a fixed palette, no software can give you a result
2019-1-25
DRAGenDROP
Hello DJI anything?
2019-1-29
Keule
Flight distance : 3733015 ft
Did you try FLIR tools
2019-1-29
Lynfa
Switzerland
This is the result using FLIR Tools
No Measurement pane.
No Parameters pane.
No Instruments tab.
Absolute useless
2019-2-6
UAVICS
India
Hi,
Is there any software that could help analyzing the thermal images taken from Mavic 2 Enterprises Dual.
All the software (including flir tool) are recognizing it as RGB (.jpg) image with no temprature data.
If there is no software...then this drone is good for nothing.
2019-2-6
TMH71
Answer from FLIR:
Hello Thomas,
I am not too familiar with the DJI Mavic drones but I do know that the Xenmuse XT have to be setup to take radiometric images, otherwise the images are flat with no temperature data.
Could you please check the save settings on the Drone and make sure they are set to take radiometric jpg files and then test some new images in Tools?
Regards,
Andrew Lohmer
Technical Support Specialist
and
Hello Thomas,
I am sorry but I am not familiar with the DJI Mavic so it may be best to speak with DJI as they have designed the drone.
I know for a fact the DJI Xenmuse XT  is capable of recording jpg files with Radiometric data.
Regards,
Andrew Lohmer
from today, so it would be great to have a statement from DJI.
i saw a youtube video from the CES in this clip, and it seems like the guy is a official FLIR guy says that we both launch the drone.
2019-2-21
DRAGenDROP
TMH71 Posted at 2-21 08:26
Answer from FLIR:
Hello Thomas,
There is no way to safe the files with that info in it with the Mavic duo.I think it's posible to program it in by DJI, i think DJI will not program it in the files for a lot of reasons!.......
Sensor is so little that it's not a good 'tempature' camera, only good for live viewing and thats it, safe the files to look at it when you are back, no info in it, only look at the diference what is hot or cold.I also do not expect DJI will answer or react on this.....
Vincent
2019-2-21
DrMrdalj
Flight distance : 1265978 ft
Serbia
DRAGenDROP Posted at 2-21 08:57
Vincent
Simple  FLIR Duo (retails  for $900) records radiometric JPEG and all metadata that can be analyzed in FLIR Tools. That is the same camera  sourced for M2ED (same thermal sensor, same optical sensor, same framerate, etc) so I do not have a clue why DJI doesn't provide at least minimum and maxium temperature and linear pallete (so JPGs can can get analyzed in Matlab if not FLIR software)
2019-2-26
DRAGenDROP
DrMrdalj Posted at 2-26 17:37
And still no answers
DJI is slepping or think, ah let the stupid duo buyers get lost
Forget it, i sell the thing and hope someone will buy it, not knowing you can do NOTING with the dual stuf junk
2019-3-2
DRAGenDROP
They will come with a answer like: oh sorry the prosessor is not capable of doing that to!
2019-3-2
Flyron
South Africa
Palette and Isotherm do not come up in Menu with a Samsung N9. It works fine with an I Phone [but no Mission available]
2019-3-4
mxklt
Flight distance : 1387283 ft
Flyron Posted at 3-4 03:47
Wrong topic.
2019-3-21
Anokadrone
Flight distance : 58327 ft
It is my understanding that the FLIR Duo R is required to take radiometric (temperature) measurements from a thermograph.  That camera looks like it was discontinued but it was up in the $3K plus range.   It looks to me like all FLIR cameras need the (-R) on the model name to get those readings.  I seriously doubt that the Mavic camera is capable of taking these readings.  It would cost about 3X (or more) than what it is now.  It appears to be a low res thermal camera and that is it.
2019-4-9
DrMrdalj
Serbia
Anokadrone Posted at 4-9 09:06
Please note that Duo-R was officially priced 1299$, while plain Duo is 999$.
Still, even plain Duo is eqiped with linear pallete and can be set to fixed themperature range, so that all photos get comparable...
Finally, I will not mention competing brand and model, which is capable of tilting camera not just downwards but upwards 90degrees as well - thst model uses same Lepton sensor and has linear pallete and manual range and comparable photos...
So, it doesn't take much to make it right.
2019-4-24
DrMrdalj
Serbia
2019-4-24
TMH71
I think that the thermal camera inside the M2E is able to capture jpg-r but Dji plan is to attract us with the M2E dual with low resolution etc to hope that we do the next step to buy the  high price models. Ok that’s business, but the thing that makes me angry about this situation is, a lot of people aks about this feature and nothing happens, no answer from DJI, but if you show some drone picture in the forum you got a official answer from DJi very fast. So people from DJI please give us an answer! Thanks
2019-4-24
Anokadrone
I think the answer is:  you get what you pay for.  Thermal cameras are very expensive, the good ones anyway.  The low resolution versions are thermal - sure - but the quality of the image is so poor that trying to glean any kind of useful data from them is futile.  If you want good quality radiometric thermographs, your talking up in the $10K range minimum for equipment that flies.
2019-4-25
TMH71
The thing is not the resolution, do you know the M2E dual, I don’t think so, i own on and the resolution is low but you can see and measure stuff and you can buy a clip on Flur cam for mobile devices with the same resolution and theses camera is able to capture jpg-r.
2019-4-25
Keule
The M2ED camera subsystem is based on a FLIR DUO R. As seen in post #17 the original FLIR DUO system is capable of recording RJPG.
The question is: Why had DJI not implemented this basic feature? Will it (recording RJPG) be available at some point?
2019-4-25
AlphaFlightNW
Flight distance : 784265 ft
Keule Posted at 4-25 03:41
Well this has peaked my interest., I am subbing to this thread to await the response.
2019-4-28
Kalle2017
Flight distance : 987310 ft
No answer from DJI to this question?
2019-6-4
kv yashwanth
India
Lynfa Posted at 2-6 00:58
[view_image]
Hey hi if possible can you share me one thermal image captured from M2E that would be great help to I want to check it's thermal capabilities
2019-8-4
DBOSKO
DJI why can't we have access to the radiometric data that you are advertising on your website?
2019-8-14
djiuser_yITbng7knZ7E
Czechia
Can i ask you, whether DJI plans to bring SW upgrade for M2ED users to save radiometric jpegs compatible with other Flir thermal imaging cameras for further analysis in Flir Tools+ or at least in some DJI SW for basic editation of saved rjpegs as it is for example at Parrot Bebop Pro Thermal drone which costs like 1/2 of M2ED? When we bought M2ED with integrated Radiometric FLIR® Thermal Sensor we supposed to save full rjpeg and we would really appreciate this upgrade. Thanks for answer.
2020-1-29
Keule
djiuser_yITbng7knZ7E Posted at 1-29 03:07
It seems that DJI secretly is planning to release some kind of analysis tool.
Since a few days an additional section in the support/download area appeared.
Unfortunately, clicking on the link, you receive a HTTP 404 error....
2020-1-29
Kalle2017
Supported Device for the DJI Thermal Analysis Tool is only: Zenmuse XT S
2020-1-29
Keule
Kalle2017 Posted at 1-29 08:10
The software (Thermal Analysis Software) looks like FLIR tools. (and with fewer features)
I am wondering why DJI is trying to invent the wheel twice, it would make more sense to simply enabling R-JPG on the M2ED ...
2020-1-29
sense_flight
Flight distance : 9232 ft
kv yashwanth Posted at 2019-8-4 11:16
Here you go pal, I am a new user and was hoping that the thermal camera would offer much more than what it actually does.  When I took this picture I actually had the spot temperature tool active on one section of the roof of this large industrial warehouse, but as you can see this has not been saved.  There are THM and SCR files saved on the SD card, with filenames that correlate to videos and pictures but I am assuming that these files are for something else as per a previous thread on this forum.
I would really appreciate a reply from DJI on this as the drone is not useful without analysis software - not what I would expect from an enterprise edition of a drone.
2020-7-2
djiuser_1XDnlStWGXbB
Flight distance : 272 ft
HEY DJI ANY WORD ON AN UPDATE FOR THE SAVING OF IMAGE WITH RADIOMETRIC DATA FOR THE M2ED?  I specifically bought this aircraft Because I started in inspection job that I need to take thermal images, With data,  Is there no way to push an update that allows us to save those images in the proper format to read them with flir tools?  I am a little disappointed in reading this because I was led to believe this aircraft would be able to take thermal images for inspections. There should be some kind of disclaimer previous to buying $3900 dollars is  Great deal of money for a camera that doesn't do what you need it to do I could have just saved my money and bought the XT for my inspire.  Is there no return policy or refund because the product is not working correctly?  I see a conversation on this thread but no response from DJI,  Is there not an app I can download to rectify this issue?
2020-8-6
DRAGenDROP
they do not give a ... about the dual users
2020-8-22
fans6f0963de
hi people,
I ask'd Dji support about and I'm still waiting for an answer but looking at their web site you can found this article
www .dji. com /it/ newsroom/news/ dji-makes-thermal-imaging-portable-with-mavic-2-enterprise-dual
get a look at this:
Dual allows users to measure temperatures and conveniently store images and temperature data for efficient reporting and analysis, adding immediate value to a range of industrial or time-sensitive operations today from utility inspections to emergency response.
sorry for the spaces but I'm not allowed to post url
2020-9-9
fansaecb3d36
Flight distance : 611165 ft
Ghana
The fact that DJI releases enterprise grade products that are advertised as taking radiometeric photos and then exports these without metadata so they can’t be analyzed later is disgraceful. Shame on you DJI! Pathetic!
We also bought an M300RTK + H20T that can’t be used for thermal mapping either because DJI doesn’t export the photos as R-JPEG so that these can be processed in Pix4D for a radiometric orthophoto with actual temperature values per pixel. So you can process the JPEG images and only get a visual thermal orthophoto.And if you think that DJIPilot has an option to select the thermal mapping camera on the H20T to map an area thermally, think again. It only provides for the H20T wide camera within the 4-sensor cluster.DJI...wow...with all that money and user input worldwide this is pathetic. Fire you software development team lead.
2020-11-1
DRAGenDROP
Haha, after one year stil not even one answer here.
What a joke DJi is!
2020-11-1
cubasis
Ghana
The only option you currently have to get any value from the Mavic 2 Enterprise Dual thermal camera is to manually click on the screen to get a temperature reading at an area of interest and then do a screen capture as attached....
2020-11-1
kabook83
Poland
Guys. This is a screen grab from your own website. "Radiometric FLIR Thermal Sensor" it says.
I simply don't understand. Why is R-JPEG not possible if you advertise it on your own site? Is is a software or hardware limitation ? If it's software, then it really should be easily fixable. If it's hardware, then I'm respectfully sorry to say that this piece of advertisement is at least misleading.
Hell, I can take R-JPEGs with my FLIR ONE PRO (identical sensor ) and a tablet.
Could we finally have an answer from your software or R&D department ?
And I cannot lead with limits and work within the boundaries
EDIT: Also, if there are adjustable modes for different emissivity materials I would like to know where I can find them. DJI Pilot, Android.
Yours,
Piotr
2020-11-8
DRAGenDROP
kabook83 Posted at 11-8 02:38
[view_image]
They do not give a ... about us, there will be a new flir drone coming and say “ look how great we are”
2020-11-8
kabook83
Poland
DRAGenDROP Posted at 11-8 03:50
You think it's worthwile to make it a separate topic ? Maybe at least the moderator will say the usual stuff, you know...
2020-11-10
paulo_souza
Brazil
Hi everybody!
After all these years we still don't have an answer from DJI. So, this is what I made to get the temperatures offline:
1- I adjusted the color palette to rainbow and the range from 0 to 100 degrees.
2- Disable MSX.
3- Take the picture/movie
At my PC I trained a neural network to calculate the temperature, based on the pixel color.
This is my result:
Original image:
Cristalsky pic:
Handheld IR camera:
Result:
2021-3-11
DRAGenDROP
paulo_souza Posted at 3-11 03:19
Hi everybody!
How you set up the nural stuff
2021-3-11
12Next >
