WAYPOINTS 2.0 TEST
6131 22 2019-1-25
DroneSupremacy
Flight distance : 998976 ft
Bulgaria
So we finally have the "Waypoints 2.0" intelligent flight mode added.
The waypoints feature itself is quite good, with plenty of options and settings to tweak in order to make it work for you.
If you want to see the waypoints in real-life, here's a video I shot today:
Hope you guys enjoy!
-Mike
2019-1-25
DJI Stephen
Super Moderator
Hello and good day DroneSupremacy. Thank you for sharing this video regarding the Waypoint 2.0 and thank you for your support. Great work.
2019-1-25
DanielVieira
Flight distance : 2937402 ft
Portugal
Nice tutorial mate, great job as allways!
To bad about SRC update
2019-1-25
bikoo
Flight distance : 1385499 ft
United Arab Emirates
thanks Mike
2019-1-25
A CW
Flight distance : 13838848 ft
Yeah, it's works perfectly well. No glitches at all.
2019-1-25
Bart B
Flight distance : 878852 ft
Never worked with the way-point's on drones, I am going to do a test around my home area, if i create a route does the drone ascend to the height of the first way-point before starting? or should you ascend manually first to the route elevation and then start? I have some tree's to clear first.
2019-1-25
RedWolf18
Flight distance : 639062 ft
Hi Bart,
AC will ascend either when you hit go from auto takeoff, or when you hit go if after manual takeoff. Essentially, whatever the choice, it will ascend as per your 1st waypoint altitude.
2019-1-25
Bart B
Awesome! thanks RedWolf18
2019-1-25
MagicRide
Flight distance : 6766027 ft
One caution when working with waypoints, is to make sure you have sufficient height to clear buildings, trees, hills etc. This requires that you know the terrain a bit before you launch.
2019-1-25
Bitesteel
Flight distance : 110151 ft
New Zealand
I see Mike struggles with the point of interest.
I’m also finding this really hard to use. When trying to select the POI, I end up with 15+ points of interest!
How does one easily select and edit this?
2019-1-25
Montfrooij
Flight distance : 1934931 ft
Good work!
2019-1-25
Bart B
Bitesteel Posted at 1-25 13:21
Same here wish there was an undo
2019-1-25
Hani
Flight distance : 1392995 ft
Great tutorial, Mike! I’ve not used waypoints before and I’ve been waiting for it.
2019-1-25
Bitesteel
New Zealand
Figured out the points of interest...
If your waypoint marker is too close to the POI, you can’t select the POI. Delete the nearest waypoint and then you can edit the POI.
2019-1-25
Esk534
Flight distance : 1349816 ft
Denmark
Nice tutorial
2019-1-26
Jesmand
Flight distance : 31680 ft
Denmark
It is not working whit my m2p
2019-1-26
Bart B
Bitesteel Posted at 1-25 23:02
Noticed that as well my flight was a close circle to home, which made the POI seem unresponsive. I also noticed that if you place a POI close to your home point it will not let you select it for edit.  I had to set the POI out a little from my home point to make the edits and move it back over my home once my edits were done.
Not a huge deal because I don't think my test scenario is a mission I would fly but someone doing real estate might.
2019-1-26
Woe
Flight distance : 4129268 ft
Well done.
2019-1-26
IcannotThinkOfAName
Flight distance : 623432 ft
Very helpful!
2019-1-26
Wiroj
Flight distance : 37612 ft
Thailand
When complete task i cannot go back to main screen
After press red button on screen it's popup "Cancel(c1) or Ok(c2)" after press ok or c2 button it's nothing happen and still same screen
2019-2-2
rogerio53
Flight distance : 168885 ft
Portugal
Hello and thank you. If I make a mission on one device may I use it on another device?
2019-2-26
apmalm
5/22/20 Two confounding problems with Waypoint 2.0.  #1. When flying between waypoints the camera progressively moves to point in the direction of the subsequent ( third) waypoint rather than the flight path direction. #2. The camera does not track the POI accurately in the center of the frame. That appears to be a consistent error seen in the Youtubes of many although it is rarely mentioned.
2020-5-22
Ratfink11
Best part I like is spending 6k for a brand new drone that I cant get it the air because this mission planner wont let me go above 30 feet... Then gives an error for flight restrictions with no info on what the actual problem is.... I have a brand new 6k pile of sh#t.  DGI got me... Scammed me... Great job guys...
2020-6-11
