djiuser_IAt91l6hRdmt Posted at 3-13 11:54
Hello,
same problem. I just used the Ronin S four days during our documentary in Jordan - and we have 1 1/2 weeks more filming. It worked all perfectly until now - suddenly the fron trigger doesnt work anymore. Camera is balanced correctly, restoring gimbal settings doesnt help, in the app recenter is working.
Hi there, sorry for the late response and the troubles with the Trigger button. Did you get it solved? If no, please make sure your trigger operation is correct. If you still cannot trigger the gimbal recenter/selfie command, the device will need to be sent in to see if there is a hardware defect. |
