Cetacean
Flight distance : 2528264 ft
JeffreyS Posted at 1-29 14:10
POI is a nice feature that I have used but it has nothing to do with the action that this thread is about. Finally a few contributors here have recognized that smooth turns and slow yaw movements are a real challenge, but are also very professional looking when done right. Next time I'm out I'll try the Yaw limit setting. I have actually placed a small ring of open cell packing foam around the stick to dampen the travel motion and help me keep it fixed throughout turns. Temporary until I get the settings right.
Aloha Jeffrey,
The wind is still blazing and gusting around here, plus we are getting more rain, so I have not gotten out to fly yet. Your packing foam solution is useful but it is better to get the electronics working for you as you noted. (I made YAW sticks to use like your packing foam.)
Besides the EXP, there are something like three other adjustments to smooth out YAW. It has been recommended to not adjust the "Gain" unless you have a clear understanding and unique need for that adjustment. If you do make a bad combination, you can return the settings to "Default".
The best thing to do is record your settings when they do what you want. Then when you get a good YAW adjustment, record it with the others that do what you want. This way, if you have to restore defaults, you have the last ones that worked for you noted.
You will probably find some really interesting combinations. There is one combination that someone used that was amazing and they thought it was a problem. Well, they solved their problem but did not tell us the combination (after we pointed out that it was a gem!) I am still looking for that combination!
BTW, when you get an EXP setting you like, remember you can apply it to "Sport Mode" to, just flip the switch. It really tames the beast, so much more manageable.
Aloha and Drone On! |
