Geebax
Jonah Posted at 1-26 11:17
When the motors are started, in GPS mode everything operates properly. When I switch to Atti mode, the props start acclerating. My Dad is holding the drone down to the floor inside, but if he wasn't, it would be gone! I am hesitnt to try it outside because I don't want it to take off and hit something. Also, I just got a Samsung Tab A Tablet to use with the drone. Could it have anything to do with that? Is there a way to reset the whole drone to default factory setting and re install firmware? I did a IMU calibration and it still behaved the same. I tried using my phone and it still didnt work. When I lay my phone on the ground the gps signal gets weak and the drone motors seem to function normal in any mode when I pick my phone up off the ground the gps signal increases to 5 bars and the motors stsart to act up?
The ATTI mode is a manual mode of flying the aircraft. In GPS mode, the aircraft is kept stable in the one place by the GPS signal received. But in ATTI mode, nothing is keeping the aircraft stable, it is able to be blown around by the wind.
The simple answer to your problem is not to put the aircraft in ATTI mode until such time as you are able to manually control it properly.
