flying over water (sea) and best filter
8020 5 2019-1-26
mardenq
Flight distance : 15932 ft
hi,had my air a couple of months but never used it yet,i do a lot of fishing (uk northumberland) and when we get into spring/summer i want to use drone to look at areas around 100 to 200 yards out in clear water to look at the kelp beds and sand bars ect,what sort of hight is best for the drone over water and what filter should i buy that will give me best view for pics and video into the water
thanks
2019-1-26
hallmark007
Flight distance : 12400594 ft
You can fly pretty low over water, but recommendations ar 15 metres over moving water, so try this first and when you feel comfortable lower your craft and see how you get on , I have flown many Times over ocean at 2 metres height with no problems, but be careful always ready to push left stick forward, you’ll find your own judgement from your flying experience will be your best judge.
Filters over the ocean on a bright day you could certainly use ND 16/ND32, if water is reasonably clear and your looking to see if can spot some kelp I recommend using circular polarized filter the will help with glare on the water again ND16/ND32.
Sounds like a lot of fun enjoy when the weather comes around.
2019-1-26
mardenq
hallmark007 Posted at 1-26 03:51
thanks for your reply,appreciate it,ill have a look for them filters
2019-1-26
Paul_IA
Flight distance : 4959019 ft
Check out the Polar Pro pack. It comes with polarized and ND filters in one set.
2019-1-26
DJI Stephen
Hello and good day mardenq. Thank you for sharing raising this inquiry. We would recommended using the DJI Mavic Air ND Filters Set ( ND4/8/16 ). These filters reduces light by 2/3/4 stops to effectively avoid over exposure, so that you can capture great photos in a wider range of environments. For reference I will be posting a link for your to be able to check the overview and the specifications of the  DJI Mavic Air ND Filters Set ( ND4/8/16 ). Thank you.
https://store.dji.com/product/ma ... t-v2&position=0
2019-1-26
mardenq
Paul_IA Posted at 1-26 07:17
thanks for reply,ill check them out online now-peter
2019-1-26
