Spazz
Flight distance : 86588 ft
hallmark007 Posted at 1-26 12:29
Nice work, does it stabilize OP when walking straight forward or cut out Camera bobbing ,
One thing I have found extremely comfortable when using OP , is to use both OP bracket and WiFi module when just hand holding filiming.
I also carry my OP as you do... much more secure in your hand for sure. My setup is rigid... its more for time/motion lapse.. but gives you a bit of extension as well ( holding it further away from you ) which is helpful in many ways... like if you have an obstacle that you need to be viewing over.. I can get close to 20" up now and still have stability with the tripod. You can add more gopro extensions as needed, just showing 3 for illustration purposes. |
