cameracollector
Flight distance : 807133 ft
I'm sorry to say that the jello effect I was seeing has not gone away. At first I thought that it had, I switched propellers with another set that I had and did a little flying and it seemed to go away. Then I had a long stretch of no flying because of the extreme cold weather we had for the last couple of months, and this past weekend when it warmed up I went out and did some more flying. While reviewing the clips I notice that the jello effect is still very noticeable in some of the clips, and the effect seems to be worse in the clips where I was hovering in one spot, whether staying still or moving up or down. The clips where I am moving laterally do not seem to be as bad, in fact the forward, backwards or sideways movement seems to cancel out most, if not all of the jello effect. In fact you will notice that in the first short clip I uploaded (DJI_0010.mov), forward movement seems to cancel most of the jello effect.
I am uploading the latest clip DJI_0231.mov to this shared dropbox folder: https://www.dropbox.com/sh/koi2kd9sv3t2mro/AAAiQzqbQmc6k8Fxlw6dNsJ_a?dl=0
The file is unedited and taken directly from the SD card.
I tried DJI Natalias suggestion moving the yaw motor gently in each direction, but as you see the issue still persists. I will redo all the calibrations again later today and try another flightm but it seems like this issue is not going away. This last incident is very dissapointing as I was doing some specific stock footage clips, and what would have been one of my best clips is unusable because of the jello.
I am wondering what my next steps should be, after spending all this money on the new P4 advanced so I would have the better camera I am unable to depend on it. I have only had this aircraft for a couple of months now.
Thanks in advance.
ps. looking at my earlier replies in this post, I notice I posted about how I can feel the vibration in the yaw motor, whereas with my P4 I cannot feel it at all. I am thinking this has something to do with the issue at hand.
