Can't charge through Wireless base adapter?
680 3 2019-1-27
rnazitto
I got the expansion accessory pack and I've used the wireless adapter and it works fine. But when I try to charge it via the USB-C port on the adapter with it plugged into the Osmo Pocket, the green light doesn't blink and it doesn't charge. Anyone else having this issue?
2019-1-27
zoom
Flight distance : 97402 ft
Hi rnazitto do a search there are a few having this problem Its seem it does not work with some standard cables
FIX is to use the original cable that came with OP give it a try
My WiFi module is about to arrive So will try myself
Cheers
2019-1-27
rnazitto
zoom Posted at 1-27 12:27
Thanks, do let me know. I'll try it, but seems a little silly it is dependent on what cable you use.
2019-1-27
Matthew Dobrski
Flight distance : 1831050 ft
rnazitto Posted at 1-27 13:21
It's because most cables can only charge the device, while others (apparently identical) can also transfer data. These, however, are much more expensive. It's vey confusing issue recently due to mass-manufactured Chinese Lightning-to-USB adapter cables able to charge only.
2019-1-27
