Quick Charging Smart Controller off of Portable Charger
4581 9 2019-1-28
RichfromHowellNJ
Flight distance : 508255 ft
Just an FYI that I'm able to use my Pocket Juice (which supports QC 3.0) and rapid charge the DJI Smart Controller.  Of course you need to use a QC 3.0 computable cable (i.e., the cable that DJI provides).  But it truly does do a quick charge right off the portable charger!
2019-1-28
DJI Stephen
Hello and good day RichfromHowellNJ. Thank you for sharing this information with us today and thank you for your support.
2019-1-28
MadMadMat
Flight distance : 2097874 ft
That's great to know I came to this forum to see if they had replaceable batteries for the smart controller. Fast charge works just as well. That's my biggest complaint about the mavic pro you can have as many batteries as you want for the aircraft but when the controller goes low it takes quite a while to charge back up.
2019-1-28
MadMadMat
2019-1-28
briano216
Flight distance : 547697 ft
I'm in Australia and need a charging method fairly quickly. Seems like the Pocket Juice is not available in Australia. I found specs on the RAVPower 20,100mAh USB-C portable charger:
Output: USB Output: 5V / 2.4A Max Type-C Output: 5V / 3A Max QC 3.0 Output: 5V / 2.4A, 6.5V~9V / 1.5A, 9V~12V / 1.2A Max
Is that OK to use on the DJI Smart Controller?
2019-10-8
akozc
Flight distance : 2019951 ft
Its suprised me MI (Xiaomi)10000mA portable wireless charger model , can fast charge the SC.
u even dont need to use SC original cable but charging cable of  MI doing well.
2019-10-9
BobB
Flight distance : 138310 ft
Good grief are some of you only getting one bird battery out of your SC's? Should be getting 5-6 batteries out of a full charge.
I guess some of you are doing a JIC experiment?
2019-10-10
akozc
BobB Posted at 10-10 01:32
BobB
SC does enough  juice to run until 3-4 smart batteries  run out their juice.
Suggest to keep the screen brightness in mid level and dont use the screen or voice recording which could reduced the battery time.
2019-10-10
BobB
akozc Posted at 10-10 01:57
BobB
ya i get 3-4 or 4-5 sometimes too and good suggestions for those not in the know
2019-10-10
phramick
Flight distance : 4053691 ft
Hi mate, the above product is no longer available in new condition, will this one do? https://www.amazon.com.au/gp/pro ... 0N82ESLNG&psc=1
2020-11-9
