Tilted horizon
923 7 2019-1-28
Adam Molik
Poland
Hi
I have calibrated osmo pocket, and I have big issue with horizon/calibration/stabilisation...
Pictures in comment. Look at the lines and grid.
This is normal ? I loose level on my gimbal. I've checked test unit in shop - this sameFirmware is up to date
2019-1-28
DJI Tony
Hi, thanks for the inquiry. May we have the model of your mobile device? Please provide the firmware and your app version for further check. Thank you for your support.
2019-1-28
hallmark007
Flight distance : 9827923 ft
If were you calibrated is the slightest bit off you may end up with tilted horizon, so make sure you are on a complete level surface.
2019-1-28
Ttrilles
And stand exactly 90 degrees in front of the object. Then you can check the horizon.
T
2019-1-28
Adam Molik
Poland
DJI Tony Posted at 1-28 10:36
samsung galaxy s8
firmware - osmo pocket - 01.03.00.20
app - 1.0.2
2019-1-28
Adam Molik
Poland
Ttrilles Posted at 1-28 11:15
T
i know, my photos was taken maybe not perfect but i assure you that there is problem with the horizon
2019-1-28
DJI Tony
Adam Molik Posted at 1-28 12:59
samsung galaxy s8
app - 1.0.2
Thanks for the prompt reply. We will coordinate this concern with our R&D team for further clarification. Thank you.
2019-1-28
Ray-CubeAce
You may well have a problem but these are not good images for evaluation. You must be perpendicular to what you shoot for evaluation. That means 90 degrees onto subject in all axis.
2019-1-28
