Ask to Take Knowledge Quiz, but never get through
5426 32 2019-1-28
djiuser_PEp4mLwh74c7
Flight distance : 11625174 ft
After activating my Smart Controller, it always asks to take the Knowledge Quiz. But it never get through when I clicked “OK” even though I have high speed internet at home. It shows the error on http://quiz.djicnd.com. After showing the error page, I cannot go back to DJI GO4 page, and need to restart the SC. Some website says we only have 4 chances to cancel to test.
What can I do? Can I take the quiz on my DJI account?
2019-1-28
DJI Tony
Hi, we do apologize for the troubles that it caused. May you please update the firmware of your unit using the DJI Assistant 2 to see if there will be changes? You could also provide us with a short video about this situation for us to coordinate it with our team for further help. You can upload the video using google drive or dropbox then provide the link here. Please refer to the link below for you to download the application.
https://www.dji.com/mavic-2/info#downloads
2019-1-28
DJI Tony Posted at 1-28 14:41
I just took some photos which show the exact the situation here.
2019-1-28
The firmware was updated within one week, version 0310.
Because the SC always asked to update new firmware 0300 (see my previous post), so I tried very hard and finally the drone firmware was updated using DJI Assistant 2  for Mavic, published at 24th of Jan, version 0300.
Nothing happened after renew, still ask me to take the quiz again and again.
2019-1-28
DJI Tony
djiuser_PEp4mLwh74c7 Posted at 1-28 15:21
We have just released new firmware V01.00.0350 with the built-in DJI GO 4 APP v4.3.12, could you please update and try again to see if the issue persists? Thank you.
2019-1-29
DJI Tony Posted at 1-29 19:40
Yes, I just updated the 0350 firmware, and the issue disappeared.
Thanks
2019-1-29
DJI Tony
djiuser_PEp4mLwh74c7 Posted at 1-29 19:47
Thanks
Glad to hear that, please keep us updated if there is any further issue.
2019-1-29
fansa31c5ba8
DJI Tony Posted at 1-29 20:07
This is still happening even on Version 360.  In fact once today, it popped in and took over the SRC screen while I was flying!   The only way I have been able to clear the problem is a full reboot of the SRC.  Unfortunately this time I was already in the air and some distance away,  I did not want to power cycle the SRC while in the air.  So I hit the manual RTH button, which still worked and waited for the aircraft to return. Once on the ground, I power cycled the SRC and cleared the problem.
I have no problem taking and passing the knowledge quiz, but the test itself does not work, it always fails.  It simply ends up pointing to failed URL going to a white screen.  Rather disconcerting after the aircraft is in the air.
2019-2-3
DJI Tony
fansa31c5ba8 Posted at 2-3 15:14
Hi, we're sorry to know about the situation. Would it be possible if you could provide us the version of your application? I'll let my team be notified in this situation for further clarification. Please keep us posted on the latest progress.
2019-2-4
merlinpp
Flight distance : 62 ft
same problem have updated since receiving smart controller and new aircraft have updated to 310, 350, 360, unable to do quiz unable to upgrade aircraft . assistant 2 v 2.06 recognizes smart controller but wont recognize mavick 2 pro tried wi fi cables no firewall ,no av, cant fly .so far just an expensive ornament
2019-2-4
MikroTX
Flight distance : 14528 ft
Hi All. I contacted the DJI Support via FB Messenger. They recommended me to use the DJI Assistant to reapply the latest firmware to my DJI Smart Controller. I tried the refresh with no luck. Also, I tried to downgrade it to the previous version and then again upgrade to the latest firmware. Still, I have the same issue described here. I am getting the Error 80" questionnaire was not found when the Quiz pop-up appears.
2019-2-4
the tanner
Yup, I am on firmware 0360 with the same problem it will not let me take the quiz!!!  What gives
2019-2-5
the tanner Posted at 2-5 13:04
I updated the firmware using dji assistant 2 for mavic, the quiz page disappeared.
2019-2-7
Could you please give us the specific time when it happened so that we can check the server? Thank you in advance.
2019-2-12
merlinpp Posted at 2-4 12:38
Does the issue persist? Could you please give us the specific time when it happened so that we can check the server? Thank you in advance.
2019-2-12
Hi there, does the issue happen every time? Could you please give us the specific time when it happened so that we can check the server? Thank you in advance.
2019-2-12
MikroTX Posted at 2-4 22:09
Hi there, sorry for the troubles, does the issue persist? Could you please give us the specific time when it happened so that we can check the server? Thank you in advance.
2019-2-12
BBradac9
Flight distance : 157477 ft
I also reapplied the .360 firmware using Assistant 2 but the quiz continues at random times.  Still unable to even take it as it just directs to a webpage with an error.  Pretty annoying stuff with my new controller.  Seems like a fix could be applied that would correct the bad website.
2019-2-12
BBradac9 Posted at 2-12 04:33
That's really annoying. Fortunately it disappeared after I undated the firmware.
2019-2-12
gunplumber
Flight distance : 902 ft
hi I received my new smart controller today and have the same problems,after 5 hours of messing about with dgi assistant and the like ive just got an exspensive brick not happy and if not resolved soon will be sending back for a refund.
2019-2-12
Martin798
just a short update having not been able to fix the error code problem with taking test as many others have exsperianced I am returning my controller to jessops tomorrow not good not happy and a complete waist of money and time,i suggest you don't buy one until problems with it are sorted out.
2019-2-17
Martin798
2019-2-17
djiuser_1iD2VvhUb5xT
DJI Mindy Posted at 2-12 04:22
Quit blowing off this issue and fix the problem now!  I have a $1900.00 drone and SC that I am afraid to fly because of this quiz screen popping up and not able to complete.  You keep saying the same thing, what is your firmware version, we have escalated blah blah blah.
FIX IT NOW OR YOU ARE GOING TO BE RECEIVING MY DRONE AND SC BACK FOR CREDIT.  THIS IS ABSURD!
2019-2-21
Has anyone received a fix for this knowledge quiz failure and white screen?  I have scoured the internet and cannot find anyone the has a fix for this.  Does everyone just give up and stick the drone in the closet?
2019-2-23
KJINTF
No fix  for me as well - software updates all done and up to date -problem continues
Hope not to have to return the equipment
2019-2-23
KJINTF
2019-2-23
djiuser_1iD2VvhUb5xT Posted at 2-21 17:10
Mine is  not fixed completely. Some time comes out  some time not.
DJI should do something immediately:
Allow to take the quiz
or remove  the item from firmware
Please!
2019-2-23
djiuser_tMutEFpqxKgv
djiuser_PEp4mLwh74c7 Posted at 2-23 12:39
I'm experiencing the same thing with the smart controller. Today, mid-flight, it took over the screen and I could not get it to go away. My home location was not ideal so I couldn't automate return to home without causing a crash. (I know, my fault). Still, DJI we need this fixed. This could easily become a safety issue with it taking over the screen like this.
2019-3-23
Lagnrmg
Was there ever a solution provided?  I received a Phantom 3 standard as a gift two years ago. I finally took it out of the box and registered it.  I updated the firmware and I still can’t get to the quiz site.  I flew it on beginners mode. I hope this thing does not lock me up after my fourth flight.
2020-5-3
Spear
Been having same problem for ages.  Now unable to use as locked out of control screen as test is not done.
If no work around is available then surely compensation is due to everyone with a brick for a drone
2020-6-23
fans9c787f79
August 15, 2020 same issue with Phantom 3 Standard... all firmware updated... was actually working fine before i did the latest update two days ago...  HELLO DJI Please Hlep ... TY...
2020-8-15
djiuser_XsXbz6Oz9Mjd
honestly the whole dji “engineer” crew must be dumb ass rocks 3 years and this problem isn’t fixed? i can’t even get my drone to take off because a white screen blocks everything honestly boutta say fuck dji and switch brands
2020-8-17
Ihrke015
fans9c787f79 Posted at 8-15 10:56
Same issue here. Ive been getting the test error for years with no test available to take but as of a couple of days ago (whenever the latest update came along) I can no longer "exit" the test and the drone is completely useless. I wiped the app from my phone and reinstalled once and was able to fly one time but now the error came back and after reinstalling it didnt work this time.
2020-8-17
