Mark The Droner
Flight distance : 2917 ft
Trackerputnam Posted at 1-29 09:07
[view_image]
I am within the hour glass blue shape around the runway. I was authorized to fly there with self authorization. But I believe you are right in that my updates are not current. When trying to start the drone an additional circle shows up not seen in this picture.
I was referring to the app's Geo map being updated or not. But the app is not the deciding factor. It's the AC that decides whether you can fly. So if I was you, I'd use a desktop/laptop and get customized authorization. It will likely take some time. Once you get the authorization, that authorization will record itself onto your AC directly provided you start up the system with an internet connection. From that point, you'll be able to fly. Your app has nothing to do with it.
As I said before, my understanding is you are self-authorized to fly in the outer edges of the hour glass with a height restriction. Flying in the closer middle area requires a custom authorization, I believe. Otherwise DJI pilots could self-authorize themselves to fly right into the runway and DJI doesn't like their customers to fly into runways unless they know for sure their customer has authorization.
I don't believe your AC FW has anything to do with solving your problem.
You can also try emailing flysafe@dji.com to get authorization, but my understanding is you're supposed to use the custom authorization process. I believe you're going to have to jump through the same hoops by email, so you'll end up wasting time doing it by email.
Good luck |
