Really need to get some filters. Was a bit windy and drone isn't flying straight, which was annoying. I'll try again and recalibrate the compass beforehand.
Thanks. It has some nice straight lines to practice with and apart from some power lines at one end, once you're above the vine level it's pretty open. Not mine, unfortunately, but the owner is a friend of mine and it gives me somewhere to practice with a bit of interest.
Not going to spend hours tweaking the photos but quite like this one. Adjusted slightly in MacOS Preview.
spandit Posted at 1-29 04:50
I have a clue or two about vineyards... and I must say, this is very neat and well kept one. For those who don't know, keeping the vineyard is a LOT of hard work..... however, it's also very rewarding experience once all that effort results in some fermented grapes juice, lol.
eYeSkYeYe Posted at 1-31 11:52
He does keep it neat. I've helped with the harvest which was backbreaking. Not that keen on the wine, mind.
spandit Posted at 1-31 11:58
Thank you! In the bright sunshine a lot of the photos were really washed out. Especially when the sun isn't that high
I'm not sure if a filter will help you out much on that part.
The contrast is just too high for the small sensor of the drone to overcome.
ND filters just block some of the light, so every part will get more dark.
You can achieve the same by setting the shutterspeed faster (or aperture if you have the M2P)
Unless you are already at the fastest shutterspeed of course.
