DJI Smart Controller Release Notes (2019.02.01)
1383 13 2019-1-29
DJI Support
Flight distance : 2408 ft
China
Overview:
  • Date: 2019.02.01
  • Smart Controller Firmware: V01.00.0360
  • DJI GO 4 App: v4.3.12
  • DJI Assistant 2: DJI Assistant 2 For Mavic v2.0.6
What’s New?
  • Added German and Spanish languages to the system. Users can set the system language in settings.
  • Optimized the button combinations. To use a button combination, users now only need to hold the back button and then press the other button.
  • Optimized the UI and descriptions for the tips section.
  • Optimized the overall user experience of the Smart Controller.
  • Updated the built-in DJI GO 4 app to v4.3.12, which includes the new Waypoints feature.
Notes:
  • To ensure optimal performance, it is recommended to update the Smart Controller to the latest firmware version.
  • If update fails, set the external microSD card to “Use as portable storage” from “Use as internal storage”, and remove the microSD card, and then retry to update. Contact DJI support if update fails for several times.
  • It is not recommended to set the external microSD card to “Use as internal storage”. This setting will be optimized in future firmware.
2019-1-29
fansd8612d99
Flight distance : 683510 ft
Belarus
Thank you!
2019-1-29
Bcor666
Flight distance : 437907 ft
just update by Assistant ?
2019-1-29
Andrew_tw
Flight distance : 742720 ft
Taiwan
thank you...
2019-1-29
bjr981s
Flight distance : 117290 ft
Fantastic Thank you DJI.
2019-1-29
Buzzyone
Flight distance : 2258251 ft
Bcor666 Posted at 1-29 06:20
You can use that or over WiFi I find Assistant quicker, but WiFi downloads in background, so you can do other things.
2019-1-29
Uwekonniha
Flight distance : 898773 ft
Danke
Ich benötige eine für Mavic Air
Ist da etwas geplant ?
2019-1-29
Bcor666
Buzzyone Posted at 1-29 07:04
2019-1-29
fansd8612d99
Belarus
New bug introduced in this version. Memory card is not visible after restart, need to reinsert it to use.
2019-1-29
DJI Natalia
Uwekonniha Posted at 1-29 08:29
Danke
Hi, thanks for the inquiry. However, DJI Smart Controller only support Mavic 2 Pro and Mavic 2 Zoom as of the moment. Thank you.
2019-1-29
djiuser_eyEd0nn8yDnl
Flight distance : 1814 ft
Leider geht es bei mir noch nicht. was mache ich falsch. danke für die Hilfe
2019-1-31
Boggus
Flight distance : 2185075 ft
When will this work with the Enterprise units?
2019-2-1
eYeSkYeYe
Croatia
Useful info. Thanks, DJI,
2019-2-1
fansd8612d99
Belarus
fansd8612d99 Posted at 1-29 13:30
This was fixed! Thanks DJI
2019-2-3
