Stops recording
605 8 2019-1-29
R0bM2P
Flight distance : 117326 ft
Hi. Why does my Mavic 2 Pro stop recording after 5 minutes
2019-1-29
Sky Donkey
Flight distance : 355157 ft
Are you recording on the build in memory card or an external one you added ?  The internal one is only 8 meg and would probably fill up in around 5 minutes depending on the quality you selected
2019-1-29
R0bM2P
Sky Donkey Posted at 1-29 13:45
I am using an SD card, it records for 5 minutes and stops and then starts again after a slight gap.
2019-1-29
Sky Donkey
It could be that you are right on the edge of what the card is able to continuously write.. whats the speed rating on the card . Also try formatting it from within the mavic itself  (just in case you didnt )
edit: try clearing the cache too
edit 2: try recording at a lower resolution... if it continues then its probably a write speed error. Try another memory card
2019-1-29
DJI Tony
Hi, we do apologize for the troubles that it caused. May we know what is the model of your SD card? Have you tried to reformat the SD card to see if there will be changes? did you manage to use a different SD card to isolate the problem? Did you manage to select the SD card under the "Storage location"? You may refer to the images below for the storage location as well as our recommended SD cards. Please keep us posted on the latest progress.
2019-1-29
Aardvark
Flight distance : 384432 ft
R0bM2P Posted at 1-29 13:52
Is this because you only see 4GB files in the folder ? If so then this is the normal process for all the DJI machines. The files normally integrate seamlessly in video editor.
2019-1-29
R0bM2P
Sky Donkey Posted at 1-29 13:59
Many thanks, I will give these options a try.
2019-1-29
R0bM2P
DJI Tony Posted at 1-29 14:51
[view_image]
Hi and thanks for your reply. The card I am using is a SanDisk Extreme Pro, 64 GB, XC 1, V30, UHS 3, A2.
I have checked the storage location and it is set to external sd card. I use 2 of the cards and all have been reformatted. I hope this is some help.
Many thanks
Rob
2019-1-29
R0bM2P
Aardvark Posted at 1-29 16:37
Thank you, I think this is what is happening, hadn't noticed it before on my Phantom 3's.
Much appreciated,
Rob
2019-1-29
