Changing format to MP4 with Smartfone
658 6 2019-1-29
John Baxter
Is there a way of changing the recording format from .MOV to .MP4 without a smartfone?  My smartfone doesn't have UBS-C port - only a Micro USB port.
Any suggestions appreciated.
John
2019-1-29
BeterBan
Austria
For 39 cents you get an USB-C to microUSB adapter :-)
2019-1-29
John Baxter
BeterBan Posted at 1-29 15:32
That simple - I didn't know that would work.  Thank you.
John
2019-1-29
DJI Gamora
Hi there, thank you for reaching out. With regards to that, you may use the Wifi module and Yes the adapter that is suggested, then change the format using the Mimo app. Thank you for your support.
2019-1-29
Ray-CubeAce
John Baxter Posted at 1-29 15:47
John
Just to add that even if you then come out of Pro mode on the Osmo Pocket, it seems to keep using the last file format you chose for video until you change it via the app again.
2019-1-29
John Baxter
The latest update has worked for me.  Also the USB C to Micro USB adaptor arrived and has worked.   The downside is that it's rather 'wobbly' connected to the phone.  A cable version would probably be better as the USB port is on the side of my current phone so not very convenient.  I don't plan to record with the phone connected so not a big problem for me.
Thanks for the suggestions and info everyone.
John
2019-1-30
Atomicodex
Flight distance : 1099268 ft
I've tried several different adapters and none have worked thus far.
2019-1-30
