What are the usages of micro SD card in Smart Controller?
12Next >
49082 42 2019-1-29
djiuser_PEp4mLwh74c7
Flight distance : 11625174 ft
As you can see that DJI Smart Controller has a micro SD slot, which supports a max 256GB micro SD card. I carefully read the manual and didn’t find out what/how the exact applications are. Is it for downloading the footage from the Controller? Or anything else?
Thanks for answer.
2019-1-29
TruGreen
Flight distance : 621909 ft
its for saving the footage from the RC. also you can insert the SD from the drone to view footage on the RC.
2019-1-29
TruGreen Posted at 1-29 21:18
Is it possible to save the footage automatically? Or need to be downloaded only?
Thanks!
2019-1-29
TruGreen
djiuser_PEp4mLwh74c7 Posted at 1-29 21:27
Thanks!
that im not sure. my stock RC was always 50/50 some times i had to download it from the drone to the device. other times it auto saved to my device. always pictures
2019-1-29
TruGreen Posted at 1-29 21:42
Sorry I didn’t make it clear. What I mean is whether it is possible to save the footage to micro sd card directly.
2019-1-29
TruGreen
djiuser_PEp4mLwh74c7 Posted at 1-29 21:52
sd in the drone yes.
sd in the smart rc not sure. i dont have mine yet. but been researching as much as i can before hand
2019-1-29
Hi there, we can expand the controller's storage with an extra microSD card and transfer the downloaded files from the controller to the microSD card. We can also view photos and videos saved in an aircraft's microSD card on the DJI Smart Controller.
We can use DJI Go 4 to select to store images and videos to the Smart Controller or on the Micro SD card. Please check more details below: GTScreenshot_20190130_144058.png
2019-1-29
JuJuMP2_User
DJI Mindy Posted at 1-29 22:41
We can use DJI Go 4 to select to store images and videos to the Smart Controller or on the Micro SD card. Please check more details below:[view_image]
Please confirm maximum size of uSD card that can be used in the Smart Controller.
Manual V1.0 says 128Gb, but 256Gb mentioned by original poster above.
Also, what format to prepare uSD card if previously used in other equipment ?
Thanks.
2019-1-30
GlynH
Flight distance : 1762336 ft
JuJuMP2_User Posted at 1-30 02:32
And where is the option to format the card on the Smart Controller?
Thanks & kind regards,
-=Glyn=-
2019-1-30
Put the microSD in the drone, format it through smart controller, and then us it for the controller. It works for me.
2019-1-30
Sorry for the late response because of the Chinese New Year. The Smart Controller supports microSD cards with a capacity of up to 128 GB and R/W speed up to UHS-I Speed Grade 3. Please refer to our Specs and the User Manuel, thanks.
2019-2-17
ff22
I am probably risking losing data but I put a 400Gig in my smart controller because it is what I had around and did not look before putting it in.  Then I saw a capacity statement and realized the size.
2019-2-17
Hillsdale.
This is a great thread. I had no idea how to get that card in my smart controller to save anything!
2019-5-12
djiuser_vLl0eLWZF0r2
Flight distance : 14022 ft
Singapore
It would be fantastic if we can save downloaded satelite maps to sd card. Right now we can only cache basic maps which are insufficient for plotting waypoints when theres no internet connection
2019-5-14
Thewoodyboy
Thanks for the information - excellent update by Mindy. Whoever distributes the new units should ensure that this stuff goes out with it.
2019-11-24
Hard Rock Jeep
Flight distance : 14941 ft
DJI Mindy Posted at 2-17 20:02
Ok, the Smart Controller takes up to 128GB.  What is the max for the Mavic 2 Pro?
2019-12-12
Trakmasters
So if I have it setup to do erything to the sd card in my smart controller, a card in the drone will have nothing on it, am I correct?
2020-2-8
raven swe
Flight distance : 517936 ft
Sweden
nope, still saves to drone card
2020-2-9
fans101a6339
TruGreen Posted at 2019-1-29 21:57
If you don’t have one yet then how the f*** would you know? I think you should sit down a be quiet! Thx.
2020-5-31
Geebax
You cannot set the SD card in the SC to record the images from the aircraft. Even if you could, the return feed is low resolution and potentially full of transmission glitches. The only decent place to record full quality pictures and video is on the SD card in the aircraft.
2020-5-31
Drone-Pilot
Flight distance : 2131073 ft
would it be possible to save apps in the RCs SD card  instead of the smart controller and be able to run the apps  from the SD card?
2020-6-3
TruGreen
fans101a6339 Posted at 5-31 16:26
wow great reply hahaha made me laugh
2020-6-28
djiuser_mv2AsCwvdUTK
I am using a 128 card in the controller as well as the Mavic 2 Pro and no problems with either. A tip I have found is to use the SRE setting when flying makes it so much easier to see especially on a really bright day. Hope this helps......Gonzo
2020-11-19
djiuser_QGjivFekuY58
Do I need a SD card for my DJI AIR 2 s as well as my smart remote at the same time ?
2021-8-23
dr6583
Flight distance : 490627 ft
djiuser_QGjivFekuY58 Posted at 8-23 21:23
Yes, that's highly recommended.  The A2S only has 8GB internal memory.  Enough for a couple 4K videos, that's about it.
And as another poster mentioned, you'll get the best results from the content on the drone's SD card than the controller's.  Good 128GB cards like the SanDisk Extreme are only $30 or so.
2021-8-24
hughdeman
DJI Mindy Posted at 2019-1-29 22:41
We can use DJI Go 4 to select to store images and videos to the Smart Controller or on the Micro SD card. Please check more details below:[view_image][Image]
Useless with DJI fly
2021-9-15
hughdeman Posted at 9-15 21:10
Hi there, we are sorry for any inconvenience caused to you. Could you please tell us more details of the issue you encountered? We will try our best to help.
2021-9-17
CraigIS
South Africa
Hey guys following this thread, so basically on the mavic 2 enterprise advanced, you still dont use the controller slot to save photos and video is that correct in my understanding?
So basically you must use the SD card in the actual aircraft?
2021-9-30
Wavicle
After either a Smart Controller firmware update (October 2021) or Air 2S firmware update (October 2021) the Cache locally when recording does not work. In fact, nothing will cache to either the internal SC memory or a Sandisk 128GB microSD card in the SC.
Something was broken by the DJI updates from one of those updates and most likely the Smart Controller update.
2021-11-8
Bob-Mini-2
Flight distance : 73114 ft
ff22, I have put a 400Gb SD in the Mini 2, it formats well, and has been recording everything just fine.  The videos download to the
Apple Mini-4 tablet using the speed transfer or just regular transfer.  Quality looks fine.
2021-11-23
dnesone
Flight distance : 2963 ft
What What is the maximum capacity of micro sd card that can be used in the New DJI PC Pro controller as used on the  Mavic 3 cine drone?
2021-12-8
yogi053
Flight distance : 26104915 ft
Wavicle Posted at 11-8 17:55
Is this still the case now?
2021-12-10
djiuser_UttrNPReEXV1
Flight distance : 1262136 ft
Things must have changed since you posted this, for the DJI Mini 3 Pro with its RC Controller.
There is no option that I can find for doing as you instruct.
Is there any way, aside from using the Quick Transfer function with a mobile device, to access & view the photos & videos taken on the M3P via the RC controller? If I don't have or use a mobile ("smartphone") device, is there any other way to do this?
The only way I've found so far has been to manually remove the SD cards from both the M3P & the RC controller & put them into my computer card slots & transfer them manually & then re-insert the cards back into their respective units, & all this at home, not in the field.
Both cards are very hard to remove & re-insert in the field, as in, either to exchange the cards from 1 unit to the other, or to remove the RC card, & then the M3P card, & then place the M3P card into the RC controller & they are so small that losing them is a definite possibility.
This seems inordinately tedious at best.
Is there something I'm missing, or has the function you describe been removed or changed with the new DJI Mini 3 Pro & its RC controller?
So far, all I can see available to do this without the tedious procedure I mentioned above is to use a mobile device.
Is there now, or will there be, any updates to allow me to do this with the M3P & its RC controller without the tedious card exchange?
Thank you for any information.
2022-8-7
2022-8-7
2022-8-7
2022-8-7
djiuser_UttrNPReEXV1 Posted at 8-7 11:12
Hi there, sorry for the late reply. May I confirm if you want to playback the footage through the DJI RC? You can directly tap the DJI Album to playback the photos/videos. If you want to download the files from the drone to your mobile device, you're recommended to use the QuickTransfer function. You may refer to:
2022-8-15
BroomRider
DJI Mindy Posted at 8-15 01:08
Hi there, sorry for the late reply. May I confirm if you want to playback the footage through the DJI RC? You can directly tap the DJI Album to playback the photos/videos. If you want to download the files from the drone to your mobile device, you're recommended to use the QuickTransfer function. You may refer to: https://www.youtube.com/watch?v=UKcvgTtaHP4&list=PL65kukZorPdMkTry0ufHNINRwbkhk9EKI
Thank you, but I don't have or use a smartphone or similar device; part of the reason that I opted to pay extra for the RC controller rather than the original-style RC-N1 type.
2022-8-20
BroomRider
2022-8-20
Bob-Mini-2
I now use a 400GB card in the Smart Controller, a 128GB in the Mavic Air2 and Mini2, then DOWNLOAD from the craft to the controller into the "Phone Album," works fine.
2022-8-20
12Next >
