JJB*
Flight distance : 12225059 ft
DJI Gamora Posted at 1-30 11:43
Hi there, thank you for reaching out and we're sorry to hear about the trouble. About the disconnection issue, nothing for you to worry as long as the home point is recorded properly and you have good reception or GPS that would be fine. And Fail safe feature will work too. And also one of the causes disconnecting from the Aircraft is interference. About Unplugging the Device from the Controller no need for you to do that seems it's not the device itself. The only thing you can say if device issue if you have the Disconnected in gray notification on the upper left hand on the camera view from the App. Thank you for your support.
A full disconnect means you cannot control the drone using the RC and a RTH procedure is started automatically 3 seconds after a full disconnect.
Sometimes only the app crashes, but the RC <> AC connection is still there, so still in control of the drone.
Sometimes the the little attitude/compass is still working, so with the use of that info you can fly the drone back home.
I use android for my go 4 app on several devices (not on the DJI list), 4 GB RAM memory and a good processor does the trick. My latest small tablet is a Xiaomi pad4, good specs and first impressions is OK.
cheers
JJB |
