RONIN-S COMPATIBILITY LIST UPDATE 2019
10153 22 2019-1-31
Davidmartin
Good Morning,  I currently work in a distributor store of DJI products. Many customers ask me about the compatibility of the RONIN-S and I have a PDF list updated on 11/19/2018. Would it be possible for you to provide me with a more updated compatibility document on this date?
I have also found different lists that say different things about the operation of the Nikon D5300 camera, which is why I need an updated list.
Many thanks.
2019-1-31
DJI Tony
Super Moderator
Hi, thanks for your inquiry. The updated camera compatibility will be located on the DJI website, specifically under the Ronin- S page. However, the one that you have is already updated and our team will automatically update this compatibility documentation when there will be additional supported cameras for Ronin-S. We would recommend paying attention to our website for further updates. You may refer to the link below for further check.
https://dl.djicdn.com/downloads/ ... y_List_20181119.pdf
2019-1-31
Dnorton
the ronin s is a disaster with older nikon cameras... im sorry i bought my ronin s to use with a d800 ...
2019-1-31
Gagamtrvael
South Korea
DJI...! PLZ NIKON Z6!!!!
2019-2-1
GagamTravel
South Korea
DJI...! PLZ PLZ NIKON Z6!!!!
2019-2-1
Vincent G
PLZ Z6 !!!
2019-2-1
Dnorton
Anyone notice that DJI have now even stopped saying that they are working on firmware to allow the ronin s to function with older Nikon???
2019-2-1
fans741f5828
Flight distance : 6259639 ft
Yes!!  Add the Nikon Z6!
2019-3-12
ibro
Turkey
DJI is very slow in adding new cameras to this list.
2019-3-12
djiuser_cQTAOeRY4bCr
Add the Fujifilm X-T3!!
2019-4-3
ClaudioVal
Uruguay
#Quick Reply Here#good afternoon I am interested in buying DJI Ronin-S Essentials Kit. I have a Canon 7D Mark II camera. I want to know if it is compatible and in what things I am limited if it is not compatible.
2019-4-3
Blanca Schroll
Austria
Can someone tell me if the dji Robin s is compatible with Sony alpha 6000? It doesn't show on the list. Thank you.
2019-4-23
mact312
So, I purchased the DJi Ronin S because I thought it supported most DSLR cameras.  I was excited to find how solid is the Ronin S!   It balanced my Nikon D5600 extremely well with my Nikkor 18-135 Lense, I came to find out that the Nikon D5600 is not even a supported camera on the list.  The close I research, it appears that the Ronin S has been focused on the higher end cameras leaving the consumer based models alone and not developing anything for them.  All the cameras on the list are $2k or above!  When will DJi support the average consumer?
2019-5-16
Yomammy
DJI Tony Posted at 1-31 12:45
https://dl.djicdn.com/downloads/Ronin-S/20181119/Ronin-S_Camera_Compatibility_List_20181119.pdf
I saw the Hasselblad X1D is on the compatibility list. DJI Tony, should I get the Ronin Essentials or the S Standard edition? Seems like the Hassy X1D won’t make use of all the accessories in the Standard kit...am I right?
2019-5-31
DJI Tony
Super Moderator
Yomammy Posted at 5-31 20:09
Hi, thanks for the inquiry. As of the time being, the Hasselblad X1D camera is not yet fully optimized with our Ronins, however, our designated department are doing their best to have this camera be fully compatible with our Ronin S. Currently, we couldn't provide appropriate cable for this particular camera as it's not yet fully optimized. Therefore, the functions of the Ronin S can't be used while using the camera. You could only balance your camera to our Ronin -S since it's under development.
2019-6-3
Nyllz72
Hello, so does any one know (from the pro s) wether there will be a firmware Update that includes the nikon d 7500 ?
I saw a video where someone Used the ronin with a System of a D7500 and a Sigma Art Lens Kit  18-35 mm  and he was able to pull Focus
My ronin App says a nikon Cam Is supposed to be conected but no performance at all.
Anny help or ideas?
Greets
Nyllz
2019-6-4
MarcoP
Portugal
I from when the release for fujifilm xt3?
2019-6-5
fans474bd045
Flight distance : 21667 ft
Japan
Hi. I am considering to purchase Ronin S but kind of hesitant because i am not sure if my canon 5D II will respond to what ronin has to offer with its hyperlapse & timelapse mode. How is it? Need help here thank you.
2019-7-4
Pzooky
Flight distance : 377382 ft
Ok lets take a moment to see if we can fix the problem, what if we take one of the provided cables cut the camera end off and solder and heat wrap a cable that fits our older cameras. An easy job for most people. With a little help from DJI and without back engineering, could we get a wiring schematic. it's only going to be 3 or 4 wires to match up? Just a thought I'v got no problem with doing it, but will it work or would we need specific software?
I've got a cheap intervalometer that works with all canons, with different connectors so surley this should be an easy thing to do?
2019-7-5
Rick Miranda
Please add the Nikon D7500!!!!
2019-9-11
Jon Cheffings
DJI PLEASE MAKE THE NIKON D7500 SHUTTER CABLE SO I CAN USE MY CAMERA WITH THE RONIN S IT WOULD BE A LIFE SAVER
2019-9-23
djiuser_hRsDH2KtLa8H
It is compatible with Canon XA30??. Than You
1-19 01:42
djiuser_uCGSRyzDVKNo
Hello
Is the ronin S working with Canon eos m50?
Thank you
2-3 06:46
