After upgrade to 01.04.00.20 visible banding/polorize on device l...
1069 9 2019-1-31
dem10
Turkey
I noticed a new banding problem on the lcd screen after doing the latest firmware (01.04.00.20 ) update. You can see the examples attached. I reset to factory settings, and tried it on all modes. Unfortunately the problem was not solved. There are no problems with videos recorded when connected to iphone. Any ideas on how to solve this problem?
2019-1-31
Atomicodex
Flight distance : 1099268 ft
Is it visible in the footage when you view it on a computer?
2019-1-31
dem10
Turkey
no just on device screen.
2019-1-31
LionelB
dem10 Posted at 1-31 08:25
Could it be a failing screen on the OP ? Haven’t seen any other reports of the problem so far, hopefully DJI Support will pick up and respond. Keep us posted & hope it works out for you.
2019-1-31
DJI Tony
Hi, we're sorry about this situation. We will coordinate this concern with our designated team for further clarification. We will keep you posted as soon as we've received the feedback. Thank you for understanding.
2019-1-31
davidvek
me too after upgrade, but now it's wanderful, cinelike and total control inside OP
2019-1-31
havrosh
Flight distance : 566785 ft
Czechia
I can see the similar artifacts on my screen like on the last picture, especially in the low light
2019-1-31
edeone
Flight distance : 164685 ft
havrosh Posted at 1-31 11:48
the same with me, with less light stronger
2019-1-31
Chris1a
Flight distance : 801 ft
Sweden
What I see in the last picture have always been present in low light on my unit, at least to some degree. I've just chalked it off as inherent to the screen (just being 1", not having wide range colors and whatnot). I didn't take notice if it had gotten worse during the few minutes I spent with the latest update. Will check when I get the chance. The other pics where you see all the pixels, I've never noticed that looking anything like that.
2019-1-31
WebParrot
Flight distance : 23625 ft
I'd suggest you head on over to support  [   https://www.dji.com/support  ], scroll to the bottom of the support page and select Online support.  Start a Chat session and provide a link to this (your post).  If there is a hardware problem you have it documented with Support and may get quicker resolution.  Get a Case #.   I'd rather take that approach that to wait to hear from the engineers.
2019-1-31
