DarthSLR
Flight distance : 1846716 ft
I often find myself wanting to create a small pano, so I would get a larger final image, but not as large as 21 (3x7) image 180 degrees pano.
If I recall correctly, in original Mavic Pro (Platinum) you could request 3x3. But in Mavic 2 Pro this is not an option anymore.
As a quick yet helpful fix, I would be very happy with an option to take 3x3 and 3x5 with the default (25%?) overlap.
However, I would like to be able to specify both the number of rows and columns, as well as to control the overlap (say with some reasonable range between 15% and 75%).
Ultimately, I would like to be able to point my UAV to the opposite corners of the target frame, optionally specify minimal overlap, and let the software calculate what grid is needed.
What do you guys think?
PSVote for as many choices as you like
