Newbie Can I fly the Mavic Pro without cell or internet connection
20735 23 2019-2-2
Dapectin
I am going to be traveling to west Texas soon and want to know if I can fly my Mavic Pro drone using my iPad mini 4 without an active cell or internet connection.  I use my drone with the iPad mini 4 now at home with no probnlems.
If yes, how?  Can someone please exlain it step by step in non-techie lingo please along with any links that might be needed.
I have reviewed other threads asking the same question and either it is not asnwered with 9yes) but enough information was given to know how to do it or uses some lingo I am not familiar with.
Thanks!
2019-2-2
DJI Stephen
Hello and good day Dapectin. Welcome to DJI forum and thank you for the inquiry. You won’t need cell service, but I would recommend you check by WiFi before you fly that you are signed into the DJI Go 4 application. If you're not signed into the application you flight limitations will be curtailed. There are some things you'll miss, like maps and in the field self-authorization etc. Some of that may be regained via using a cell phone. Thank you.
2019-2-2
Bob Brown
Flight distance : 4209662 ft
There is a good chance you will not be able to fly with updated firmware and no internet access to unlock.  It seems that DJI will try to ruin every single flight with a NFZ or unlock authorization that will require a txt message and internet access on the iPad. I have had this experience many times before getting NLD mod.
2019-2-2
Bob1102
Bob Brown Posted at 2-2 18:15
I'm getting ready to go with NLD mod myself, I'm getting real tired of waiting on DJI to reverse there latest update. I can't even start mine in my back yard which I was able to do before the last firmware update. Once the word gets out about this NFZ issue DJI will be losing a lot of customers.
2019-2-2
HedgeTrimmer
Before leaving, check the places in West Texas you plan to fly your Mavic Pro at.
Make sure areas are not NFZs and there will not be any temporary flight restrictions in place during those times.
Assuming areas have no drone flight restrictions and areas are not mistakenly flagged by DJI's software, then you do not need internet access to fly your Mavic Pro.
Some of us have gotten to where we turn off all radio transmissions (BlueTooth, WiFi, Cellular) on our SmartDevices prior to heading out to fly.  Which also prevents the Pain-n-Rear last minute system software updates.
2019-2-2
Lucas775
Flight distance : 50642090 ft
Short answer yes, long answer yesssssssssss
2019-2-2
Boffin
Hi Dapectin , If you know the locations that you plan to fly over, download the maps of the area to your iPad before leaving home, zoom in on and around all the locations to cache the maps and have fun
2019-2-2
hallmark007
Flight distance : 9827923 ft
It’s pretty simple, you don’t ever need WiFi to fly, before leaving home if you think you may be at an area with no WiFi stay signed into app then check before you leave for updates, checkNFZ on maps from dji and you should be good to fly in all areas that are free from NFZ .
You never need WiFi to fly, you need WiFi for maps which no one uses or at least very few , but even updates can be postponed until your in WiFi area. You don’t need updates to fly just ignore them.
2019-2-3
Aardvark
Flight distance : 384432 ft
Yes you can fly without wifi or cell data. The maps can be examined and cached at home if desired for use when no wifi or cell available. As DJI Stephen points out make sure you have logged into your DJI account on the DJI Go 4 App' you are using when at home. All you need to do when on location is power all up and fly.
As some have said you would need to be aware if any authorisations needed, which would need a connection. If you have a cellphone  (with a data plan), you could set it up as a wifi hotspot if needed.
2019-2-3
Dapectin
ok what does NLD mean, someone used that abbreviation above.  If I download an offline map using google maps onto my iPad mini 4 of the area I want to fly, does the remote control or drone need to be on and powered when I do this?
I am going to Big Bend National Park, way out in the middle of nowhere.
Once I download the map using google maps, is that all I need to do?
Someone said .
Why does Bob Brown say "There is a good chance you will not be able to fly with updated firmware and no internet access to unlock", and what does that mean?
Sorry, as I said, completely new guy here, I'm not a techie, and i don't know the lingo.
2019-2-3
hallmark007
Dapectin Posted at 2-3 06:30
NLD Mod is a hack you can get that will allow you fly in NFZ, but I don’t recommend as you may be flying illegally, Bob was also just being cynical, he’s obviously having some problems with NFZ’s.
If your flying in a National Park you may need to check if it’s a NFZ .
2019-2-3
Aardvark
"Once I download the map using google maps, is that all I need to do?"
You don't need to use google for maps. There is an option in DJI Go 4 to 'cache map in the background'.
So when at home with wifi connection, open DJI Go 4 and tap on the map to take it to full screen, then drag map to area you plan to fly and zoom in and scan around. DJI Go 4 should preserve this data so when on location it uses this 'cached' map instead of needing to download fresh data.
2019-2-3
Aardvark
You should be aware there is a ban on flying in National Parks in the USA.
https://www.nps.gov/articles/unm ... -national-parks.htm
2019-2-3
AG0N-Gary
Flight distance : 700846 ft
No flying from National Parks.  Technically, you can fly over a park, just like an airplane can.  But you cannot take off, land, or control from within the park.
2019-2-3
Bob Brown
hallmark007 Posted at 2-3 08:06
I am being realistic to my experience. My guess is that most that do not have issues do not live around or near an airport or NFZ. I live within a NFZ that should not be an NFZ at all.. class G airspace. I had to unlock constantly and finally got the 3 month unlock... that worked as long as I renewed it every 3 months and if I wanted to fly outside of that unlocked NFZ I had to disable it and unlock again. SO RIDICULOUS!  NLD is a mod that honestly made things work. To be clear, NLD does not remove consequences it just lets you be a grown up and make your own decisions. LOVE IT! --- Oh and Big Bend National Park/ any National Parks are a no fly. NLD will allow the flight but the consequences are fines, confiscation and possible jail time if you are caught.
Please report back after your trip.. curious if all these people that say you can fly without internet or cell service are correct. I hope for your sake they are right.
Good luck!
2019-2-4
Aardvark
Bob Brown Posted at 2-4 07:31
" I hope for your sake they are right."
And what makes you think they are not right ? It has been pointed out that if authorisation is required then a data connection will be needed. Authorisation is easily checked by looking at DJIs flysafe maps. If no authorisation needed then no wifi or cell data needed.
All my flights are without wifi or cell data connection using an iPad pro 9.7.
2019-2-4
hallmark007
I sympathize with you and the problems your having, but you are wrong you don’t need Internet WiFi to fly any dji aircraft, that’s a fact and is also the answer to one of questions asked by OP.
2019-2-4
Bob Brown
hallmark007 Posted at 2-4 10:45
You misunderstand. I no longer have unlock problems with my AC. It works perfectly now. I click cancel on the unlock nag and I fly. I would agree though that if not in a NFZ and no unlocks enabled prior you can fly without internet. Still in my experience this has not been the case since I live and fly within a NFZ. I had to have internet and a mobile device to fly. Period.
This conversation is moot since the OP sounds like he wants to fly in a National Park so he will not get to fly under DJI NFZ and FAA rules.
2019-2-5
Bob Brown
Aardvark Posted at 2-4 10:01
Agreed. My experience has been all NFZ related.
I did have an instance where I had the NFZ area unlocked and went outside the NFZ and tried to fly without internet. No fly / flight ruined because I forgot to bring my cell phone. So just be sure that if you do unlock in a NFZ and then go outside of it... you will need to authorize to fly again or can do it before you go.
2019-2-5
Aardvark
Bob Brown Posted at 2-5 08:35
"My experience has been all NFZ related."
It must've been difficult for you at times to fly. In U.K and particularly North Scotland there are few problems regarding airfield density. But certainly awareness of military activity, and flying to the CAA regulations can feel a bit prohibiting sometimes.
2019-2-5
Bill B
Flight distance : 319245 ft
HedgeTrimmer Posted at 2-2 21:32
Perfect response from Hedge here. take his advise before leaving. To save yourself a lot of grief as you continue flying and using your drone, DO NOT update any firmware going forward. If your drone is flying good for you now. DO NOT update, even if it tells you to in the DJIgo app. Just ignore all flysafe updates and go4 updates turn off auto updates on your phone and leave everything alone if it is working. Have fun.
2019-2-6
Rj-Florida
Flight distance : 16804 ft
VIOLATION to fly within any National Park. See article for reference. Good Luck! https://medium.com/@askdroneu/what-are-the-rules-for-flying-your-drone-in-national-parks-and-national-forests-1d27554984ad
2020-3-13
fans7e30011f
I fly everyday in a nfz, in my back yard, and also fly alot in open zones, I have never had to unlock the license to fly in an open zone, in fact, the blue zone I live in ends 100ft out from where I fly, and always fly from the blue zone into the open zone with out any warnings,Tim
2020-3-13
djiuser_8mdYHpDcQ1fW
Flight distance : 4629 ft
DJI Stephen Posted at 2019-2-2 09:00
Hi Stephen please please give me up to date accurate infirmation.   I have just recieved my new phone , a Samsung S21 Ultra.   Will it be compatable and safe to fly my Spark using the DJI Go4.   Many thanks
Kind regards
Ray
2021-10-27
