Udo13
Flight distance : 257188 ft
andrei193 Posted at 3-8 02:21
So before I send it back, I said to make one last test. I used a combination of an original apple charger (5v 1A) and a usb c cable from the LG fast charger. Guess what, it didn't get hot and reached 100% in an hour and 45 minutes. So confusing. It's either the cable is defective or is incompatible with chargers of less than 2A. I have ordered a samsung fast charger wit a 5V 2A. I will test this again and see what decision I make. The osmo pocket seem to perform as expected, I evan tested the battery life and it reaches 140 minutes in 1080p 30fps with no gimbal movement. Can a DJI representative say if there is a posibility that the cable could simply not be compatible with certain chargers or is a case of defective cable?
From the beginning I did not get the idea to load the Pocket with a 1 A charger.
As with other devices, Actioncam, iPad, iPhone, etc.,
I also charge the Pocket with a 2A charger.
Anker 24W 2 Port USB Charger
It is also available as a car charger
https://www.amazon.de/gp/product ... e?ie=UTF8&psc=1
My powerbank also has two USB ports
-1A
-2 A (I take only this for the Pocket, and s.o., it is faster)
