SMART CONTROLLER UNIQUE POWER ADAPTOR
6543 6 2019-2-5
777ace
Flight distance : 127316 ft
Has anyone noticed that the Smart Controller Power Adaptor QC24-US  is not your typical 5 Volt 2 Amp USB charger? The owners manual says you must use this unit or a certified replacement that outputs 12 VOLTS at 2 AMPS. I can’t find any such charger anywhere on the internet that outputs 12 volts to a USB outlet! This wouldn’t be a big deal if the DJI Store was selling replacements, but it’s not even listed for sale, nor is the beefy cable. So my Smart Controller becomes a brick if I lose or misplace the DJI charger?
2019-2-5
DJI Tony
Hi, thanks for the inquiry. Actually, It can be fully charged using the 5V/2A charger when the controller is powered off, and it takes about 340 minutes. When the controller is powered on, it cannot be fully charged as the controller consumes power faster than its charging rate. Please let us know if you have other concerns. Thank you for your support.
2019-2-5
Red Ben
Flight distance : 8346 ft
this seems to have correct spec  https://www.amazon.com/Charger-RAVPower-Adapter-Compatible-Wireless/dp/B07SJ3TJRT/ref=dp_ob_title_wld?th=1
2019-9-1
Red Ben
this seems to have correct specs https://www.amazon.com/Charger-RAVPower-Adapter-Compatible-Wireless/dp/B07SJ3TJRT/ref=dp_ob_title_wld?th=1
2019-9-1
Dioden
Sweden
I just bought a Smartcontroller,with wrong charger. Wrong jacket, I got a US plug on the charger, I'm living in Sweden. So there is no fast charge for me. Bummer
2019-10-21
Roterdan
Flight distance : 2515646 ft
Brazil
I use a Moto Z3's charger, my Smart Controller charge in fast mode with this adaptar.
2019-10-25
Horus303
Flight distance : 57484 ft
DJI Tony Posted at 2019-2-5 12:58
can I use a macbook pro charger to charge the smart controller (61W) or is that too much power to go through it?
2020-1-8
