DJI Tony
carlosnino Posted at 2-7 14:40
Thank you for your reply. I tried the software in a Macbook Pro with Mojave and it does not connect to the gimbal via Bluetooth. I tried reboting and restarting both Mac and gimbal but nothing changes. My Android LG V30 sees the gimbal via Bluetooth but does not connect directly. I assume the it does connect with the android Ronin Assistant because it tells me that the password is incorrect.
Is the default gimbal bluetooth name Gimbal1?
Hi, thanks for the prompt reply. Please refer to the instruction below for you to reset the password of your Ronin M.
First, kindly remove the battery and clean the contact/copper plate with a piece of non-dust cloth, then when you're about to put it back, please insert the battery with fine strength to push it in so that it will be tightly and firmly connected.
- Connect the Gimbal to your computer using a micro USB Cable and launch the Gimbal Assistant. Note: The light indicator on the assistant software should be Green blinking Blue.
- Once you are connected, hit the default button and Reset Password on the assistant software.
Please keep us posted on the latest progress. Thank you for continued support. |
