Half-Press for focus still not available on Sony??
2895 19 2019-2-7
Spruce_Moose
Hi, i am wondering if the option to half-press the record button on the Ronin-S to aquire a focus point, will ever be available on the Sony mirrorless range?
The perfect scenario would be, the ability to half-press the record button to aquire a focus point, then hit record knowing that its not automatically going to search for a focus point when i move.
2019-2-7
arthurbikemad
Flight distance : 49954 ft
I know this is a Sony post but just wanted to add its not completely fixed with Canon, now works in stills mode but not in movie mode....
Good luck with your Sony.
2019-2-9
Hi Spruce_Moose, half-pressing the Camera Control Button to autofocus is available for many Sony series cameras. By focusing when you move, do you mean the follow focus function? If yes, it is not available for Sony. At present, the Focus Motor has been released, and it can be used to control the focus and zoom function of the camera. Please correct me if I understand incorrectly. Thank you.
2019-2-14
Spruce_Moose
Hi Mindy, the camera is already automatically focusing so i don't understand what the use of the half-press to focus button? Currently this button only works in AFC, will this button ever be able to work while in MF mode on sony cameras?
2019-3-17
AVsupport
Flight distance : 618734 ft
This:
I can confirm: A7iii/MMC 'Trigger Auto Focus' function is in fact: 'not working'.
I have reported this a few times already...It used to be working a few firmwares ago..
Hoping for a fix
2019-3-17
Hi AVsupport, manual focus refers to the focus mode by turning the lens focus ring or by pressing the direction button to get a clear focus.
The principle of controlling the camera's focus via Ronin-S and half-pressing the camera shutter for autofocus is the same. The manual focus mode cannot trigger the camera's autofocus function with Multi cable, sorry for the inconvenience caused.
2019-3-18
Spruce_Moose Posted at 3-17 17:22
Hi Spruce-Moose, manual focus refers to the focus mode by turning the lens focus ring or by pressing the direction button to get a clear focus. The principle of controlling the camera's focus via Ronin-S and half-pressing the camera shutter for autofocus is the same. The manual focus mode cannot trigger the camera's autofocus function with Multi cable, sorry for the inconvenience caused.
2019-3-18
AVsupport
DJI Mindy Posted at 3-18 00:59
Sorry Mindy, but this is not working in AF-C mode, as indicated. Not manual focus, of course not.
The half-press on gimbal-record button should act like the half-press shutter button on the camera, and it doesn't. It did work, a little while ago, but we lost the functionality.
Please reinvestigate the issue, without the misunderstanding.
2019-3-18
Spruce_Moose
DJI Mindy Posted at 3-18 01:00
With my Sony a7rII, I operate my camera in Manual focus when filming and through an option known as back-button-focus and i am able to switch/hold between AFC and MF at the push of a button to acquire a point of focus. Im guessing the Ronin-S is limited to its capabilities with Sony and thus will never have this option?
2019-3-18
Spruce_Moose
AVsupport Posted at 3-18 04:12
I'm interested to know how/why you used the button to focus when it was actually working? My understanding is the half press to focus button only works when in AFC mode yet, when filming in AFC, the camera is already looking for a focus point so i don't understand what you would use the button for?
2019-3-18
AVsupport
Spruce_Moose Posted at 3-18 15:02
you use the button in AFC mode if AF is not doing its job properly, you can force a quick refocus. It's quite useful actually. Especially when your AF speeds are slow to avoid sudden jumps, but you quickly need to go back to a sharp starting point etc...
2019-3-19
AVsupport
2019-3-19
Thanks for your feedback, I will report to engineers for further test and come back to you soon.
2019-3-20
Spruce_Moose Posted at 3-18 14:59
That is not available in AF mode via the Ronin-S with Multi cable currently, sorry again for the inconvenience.
2019-3-20
Hi AVsupport, our engineers have tested that half-pressing the record button can trigger the Auto Focus in AF-C mode, we will need a short video for further verification, any chance to share with us? Does it happen after updating to the latest firmware? What lenses are you using?
2019-3-21
AVsupport
DJI Mindy Posted at 3-21 04:52
There you go Mindy.
I didn't spent much time making this video, but I think you get the idea ;-)
add: not having this issue with Sony A6300 & 18105f4.
Also having this issue with A7iii & 18105f4.
So this might be an A7iii thing ?
2019-3-21
AVsupport Posted at 3-21 20:21
There you go Mindy.
https://youtu.be/sYGOxlLVMms
Appreciate your time to take the video, we have forwarded to our engineers for further analysis, once there is any update, I will keep you updated.
2019-3-22
AVsupport
DJI Mindy Posted at 3-22 03:05
thank you Mindy, as always, hope this helps ;-)
2019-3-22
AVsupport Posted at 3-22 04:45
You are most welcome, I will follow it up and update to you as soon as possible.
2019-3-23
squandre
Belgium
I can also confirm that the half-press isn't working properly anymore.
2019-3-28
