Jerky or obstructed footage
724 10 2019-2-9
Sonnyrolex
My video is distorted (lines across screen) when I replay it on the windows player and on the realone player it is real jerky. I know some of the jerkyness is due to my inexperience but it does not flow.  Thank you. I'm using a Sandisk ultra 64 gb xc micro.Any suggestions.
2019-2-9
DJI Natalia
Hi, we're sorry to hear about that. May I know what happened prior to the issue? Does it happen both in the SD card and live-feed? Can you please provide a sample video of the issue so that we can check it on our end? You can upload it using google-drive or Dropbox and provide the link here. You can also try to refresh the firmware of your drone via DJI Assistant 2. Let see if this will work. Thanks.
2019-2-9
Sonnyrolex
DJI Natalia Posted at 2-9 11:51
Installing dropbox might be a few.
2019-2-9
Sonnyrolex
https://www.dropbox.com/s/mtnv81wp82ta6ys/DJI_0002.MOV?dl=0
Only happens on SD card. Thank you
2019-2-9
DJI Natalia
Sonnyrolex Posted at 2-9 13:36
Hi, thanks for the quick reply. Can you please try to reformat your SD card? Can I also have a picture of your SD card so I can check if this is compatible? Thanks.
2019-2-9
Sonnyrolex
DJI Natalia Posted at 2-9 14:55
2019-2-9
Sonnyrolex
Sonnyrolex Posted at 2-9 16:51
[Image]
Already reformatted card and no luck
2019-2-9
DJI Natalia
Sonnyrolex Posted at 2-9 16:52
Can you please try to use different SD card? Again, sorry for the inconvenience.
2019-2-9
Sonnyrolex
Tried another card and same thing.. I just ordered the one pictured below
2019-2-9
Sonnyrolex
Still have the same problem. What to do now?
2019-2-13
Sonnyrolex
I just played the dropbox video that i posted earlier and the video is fine...How is that?
At home My video is distorted (lines across screen) when I replay it on the windows player and on the realone player it is real jerky. I know some of the jerkyness is due to my inexperience but it does not flow.
2019-2-14
