Joemar7
American Samoa
You set up your OP based on the lighting conditions in your environment. I try to record in 24p or 30p at night and hardly at 60p. In either case, in Premiere Pro I use a video noise plug-in called Neat Video. Also, I use manual settings only in a controlled environment where the light is constant. I don't follow the 180-degree shutter angle rule at low light unless I have a lamp with me. Doubling your shutter speed means less light. Last, If it's mixed lighting like walking from a dark to a brighter room, street, or pointing towards headlights etc, I use auto. The OP does a pretty good job overall in auto. |
